Prusa SL1 Speed Support blocker
Lu
 Lu
(@lu-2)
Hey,
is there a support blocker also for the SL1 Speed? Or is there an easy way to remove support structures within an object without having to click on each one individually?
Thanks 🙂
Opublikowany : 26/07/2022 9:55 am
Lichtjaeger
(@lichtjaeger)
RE: Prusa SL1 Speed Support blocker
You can select multiple at once by holding shift and drag-select using the mouse.
Opublikowany : 26/07/2022 4:30 pm
