Difficulty printing with Loctite 3843 black on the SL1S
So I've been having a problem of part way through a print the part detaches from the supports. I think I need to adjust one or more of the following settings but I'm not sure which would be most effective. All the listed settings are the standard that Prusa defined. Which should I vary and by how much? Which won't have any effect on the adhesion between the supports and the part?
Pinhead front diameter (current setting .5 mm)
Head penetration (current setting .5 mm)
Pinhead width (current setting 3 mm)
Support points density (100 %)
Minimal distance of the support points (current setting 1 mm)
Thanks all,
-Kirby
Publié : 20/03/2025 8:29 pm
