Anyone have any good profiles for printing minis?
gnat
 gnat
(@gnat)
I've been using the default settings for 0.025mm prints only changing the exposure times for my resin of choice (Elegoo water washable).
I think I've about got warping at the bottom edge fixed by creating a line of almost solid supports along the lowest edge until it gets some meat on the part.
Supports are killing me though. At the default setting no matter what I do I either end up with a bunch nubs that the clippers couldn't nip (which can then be a PITA to clean up in a tight/detailed area) or a divot is left behind where the support snaps off on it's own. I've tried reducing the tip size (0.1mm) and penetration (0.2mm), but so far all my tests have failed due to supports failing. Where the supports don't fail, however, the supports are popping off with ease while washing and barely leaving any marks to clean up.
Anyone have any good tips or settings to share about how to get less troublesome supports on small detailed prints?
MMU tips and troubleshooting
Posted : 10/12/2020 9:37 pm
Michael
(@michael-4)
RE: Anyone have any good profiles for printing minis?
I don't use supports (Well, I rarely use supports). Printing directly on the print bed gets rid of any nubs
Posted : 23/12/2020 5:19 am
Mike
 Mike
(@mike)
@michael-19
What resin are you using and exposures ?
Posted : 14/03/2021 12:17 am
