UV light calibration error: Requested intensity cannot be reached by max. allowed PWM
gebi
 gebi
(@gebi)
Recently I have failed prints with my SL1 as these were not hardened enough and the prints a extremely soft and some parts a missing. My first guess was, that the UV LED's has a problem. Thus, I replaced the UV LED's with the original spare part.
No changes.
Next, I  performed the UV intensity calibration with the UV calibrator (bought together with the LCD screen) under firmware 1.4.
This gives me the following error:
UV error
Looks like that the driver electronics for the UV LED's have a problem. Somebody else encountered such problems?
New driver board ?
Posted : 23/07/2020 10:58 am
Akshay K
(@akshay-k)
RE: UV light calibration error: Requested intensity cannot be reached by max. allowed PWM
Did you get any help with that?
I got the same problem in replacing new LCD Display.
Please let me know if you get anything.
Posted : 11/11/2020 7:51 am
Adam
 Adam
(@adam-18)
I'm having the same issue.
Posted : 06/01/2021 3:03 pm
gebi
 gebi
(@gebi)
@adam-18
By replacing the LCD the printer is working again. the LCD has a very limited lifetime. My interpretation is, that a degraded LCD has low contrast, and therefore not enough light is reaching the resin....
Posted : 06/01/2021 7:23 pm
Adam
 Adam
(@adam-18)
@gebi
Thanks for the reply. By LCD do you mean the print display (pictured below)?  If so, I just replaced it and am getting this error calibrating it.
Posted : 07/01/2021 12:44 pm
Piranha
(@piranha)
Have you found a solution?
Posted : 17/04/2022 5:11 pm
