UV display connection detached
Jxyzero
(@jxyzero)
Hello! Happy New Year as I'm sure we all want/need it! Unfortunately my new year has begun with problems 🙁 Most recently, I had a major resin leak (worst I've ever had) - I'm guessing to there being a small gap in the FEP film, causing a leak inside the printer. I've done my best to clean it up but as yet have not turned it ON.
While cleaning, I've run into an issue that I'm not even sure what to do about. While cleaning the under side of the UV display, this attachment (which seems to have been hot glue gun'd down) has come out? Is this a separate cable piece that I need to replace? Can I just 'connect it' and hot glue gun it back down?
Any help with this is extremely appreciated as I'm eager to get some new prints in for the new year!
Thanks in advance!
Opublikowany : 03/01/2021 12:10 am
