					                		Touchscreen stuck in some kind of loop... - Hardware, firmware and software help                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-sl1-hardware-firmware-and-software-help/touchscreen-stuck-in-some-kind-of-loop/</link>
                <lastBuildDate>Sat, 11 Apr 2026 06:13:48 +0000</lastBuildDate>
                        <title>RE: Touchscreen stuck in some kind of loop...</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-sl1-hardware-firmware-and-software-help/touchscreen-stuck-in-some-kind-of-loop/#post-782146</link>
                        <pubDate>Sat, 14 Feb 2026 14:00:38 +0000</pubDate>
                        <description><![CDATA[Hi, thanks for your reply!I think it supports Prusa Link, i will try on monday!]]></description>
                        <content:encoded><![CDATA[<p>Hi, thanks for your reply!</p><p>I think it supports Prusa Link, i will try on monday!</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-sl1-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>kgbengt</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-sl1-hardware-firmware-and-software-help/touchscreen-stuck-in-some-kind-of-loop/#post-782146</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-sl1-hardware-firmware-and-software-help/touchscreen-stuck-in-some-kind-of-loop/#post-782143</link>
                        <pubDate>Sat, 14 Feb 2026 12:08:43 +0000</pubDate>
                        <description><![CDATA[Does the resin printer support  PrusaLink? On Core One, I stopped using PrusaConnect, as it adds no benefit (to me) just problems when it doesn&#039;t work. PrusaLink stays within my local networ...]]></description>
                        <content:encoded><![CDATA[<p>Does the resin printer support  PrusaLink? On Core One, I stopped using PrusaConnect, as it adds no benefit (to me) just problems when it doesn't work. PrusaLink stays within my local network. I still keep the printer online so I can monitor remotely.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-sl1-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>mnentwig</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-sl1-hardware-firmware-and-software-help/touchscreen-stuck-in-some-kind-of-loop/#post-782143</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-sl1-hardware-firmware-and-software-help/touchscreen-stuck-in-some-kind-of-loop/#post-782130</link>
                        <pubDate>Sat, 14 Feb 2026 06:45:18 +0000</pubDate>
                        <description><![CDATA[After further trying and testing i found that if i just use usb for printfiles it works. As soon as i connect the printer to Prusa Connect and send a file the problem starts. I can start the...]]></description>
                        <content:encoded><![CDATA[<p>After further trying and testing i found that if i just use usb for printfiles it works. As soon as i connect the printer to Prusa Connect and send a file the problem starts. I can start the print but after a while it starts to loop through menus again. However it stops looping when i disconnect the network cable. If i unregister the printer from Prusa Connect i can connect the network cable without it starting to misbehave. I suspect it's some problem with Prusa Connect but i don't know how to fix it. </p><p>I suspect there is no one from Prusa that checks this forum but i can't find another support channel. Pretty bad for a 2k printer. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-sl1-hardware-firmware-and-software-help/touchscreen-stuck-in-some-kind-of-loop/#post-782130</guid>
                        <title>Touchscreen stuck in some kind of loop...</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-sl1-hardware-firmware-and-software-help/touchscreen-stuck-in-some-kind-of-loop/#post-774305</link>
                        <pubDate>Mon, 15 Dec 2025 13:16:17 +0000</pubDate>
                        <description><![CDATA[Hi,I just got the SL1S-printer for my workplace and have successfully printed some parts, but now it won&#039;t work anymore..When i try to start a new print, the display start to loop through 3-...]]></description>
                        <content:encoded><![CDATA[<p>Hi,</p><p>I just got the SL1S-printer for my workplace and have successfully printed some parts, but now it won't work anymore..</p><p>When i try to start a new print, the display start to loop through 3-4 menus and i cant do anything but shut off. </p><p>I've done factory reset and start-up calibrations and it seems to work, but as soon as i try to print a file it starts looping again.</p><p>Anyone got an idea whats happening? </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-sl1-hardware-firmware-and-software-help/touchscreen-stuck-in-some-kind-of-loop/#post-774305</guid>
