Tilt Time not beeing exported to SL1-File
heiner
(@heiner)
I'm having a problem with the Prusa Slicer (v 2.2.0). In "printer settings" I set the slow and fast tilt time. After exporting it doesn't seem have an influence on the printer. When opening the config-file in the SL1-file, there is no mention of a tilt time.
How can I set the tilt time, in a way the printer recognizes it?
Postato : 12/06/2020 11:07 am
Lichtjaeger
(@lichtjaeger)
RE: Tilt Time not beeing exported to SL1-File
You set them at the printer. The values in the slicer are only for calculating the print time.
Postato : 12/06/2020 11:20 am
heiner
(@heiner)
thank you for your quick answer. Where can I find this setting? I only find the setting for the tilt area fill.
Postato : 12/06/2020 11:55 am
Olef
 Olef
(@olef)
I don't think it is a setting. The SL1 measures its own tilt time during first time calibration and reports it on the screen for you. Then you can set the measured values in the slicer to give you accurate print estimates.
Postato : 18/06/2020 6:16 am
yanson
(@yanson)
By the way, how you open the config file in SL1 file?
Postato : 25/04/2021 6:09 am
WidgetCeramics
(@widgetceramics)
Did anyone find a solution? I am still having this issue. There doesn't appear to be an easy way to slow the real tilt time of the vat, other than toggling the "fast" vs. "slow" option on the printer itself vis the LCD, while getting a print job ready.
Postato : 21/10/2021 8:03 pm
ResPrint
(@resprint)
Posted by: @yanson
If it's still a concern: The .sl1 file is an archive, which you can unzip. It will reveal images for each layer, a thumbnail folder and two .ini files (config and prusaslicer).
Regarding the tilt times: There is a "numFast" and "numSlow" in the config.ini file. The numFast I see matches the total of layers. I didn't find a way in the prusa slicer to set them, but I could imagine these to values to determine the tilt time (not sure though!). Edit: I don't mean to set the time itself, but whether the slow or the fast tilt should be used for the layers. I don't know what happens if you mix those values (say 50:50). I haven't made any tests on that account.
Questo post è stato modificato 4 years fa da ResPrint
Postato : 22/10/2021 7:53 am
