RPM of rear fan not in range!
antonio.rodama
(@antonio-rodama)
Hello
Sorry for my english, i am spanish.
Today I got the coveted sl1, unfortunately, when doing the "wizard" has given an error "RPM of rear fan not in range", I tried to disassemble the fan, observe it and have done several tests, removing the particulate filter , with orange lid open, closed, etc ...
I have passed the "wizard" and I have made a calibration, when I started printing a test piece it has given me again the error that the back fan does not work, at the moment the fan is working and the impression I am doing.
Any idea what it could be?
the complete error :
Please check if the fan is connected correctly
RPM data: [1111, 1111, 1500, 2142, 2307, 2000, 1666, 1250] avg 1635
Postato : 20/08/2019 4:41 pm
Henry Casson
(@henry-casson)
RE: RPM of rear fan not in range!
Let me join you. I am stuck at exactly the same error, after boasting about my construction ability. In my case the average speed is only 1450 or so. I did the same troubleshooting as you did.I note that the advanced settings show a rear fan speed of 1000. I have whined to info@, but have not yet had a reply
Attachment removed
Retired doc, should have been an engineer.
Postato : 20/08/2019 5:17 pm
info@.... takes a while to respond...
Live chat is usually more responsive
You can find Live Chat, on the Eshop page, bottom right hand corner
Postato : 20/08/2019 9:03 pm
Henry Casson
(@henry-casson)
Had a reply from support and conversation is ongoing.
Postato : 20/08/2019 10:49 pm
antonio.rodama
(@antonio-rodama)
Posted by: henry.c
Hello Henry
Any support response? I'm out now and I can't contact.
My printer is not in kit, it is completely assembled by prusa
Postato : 21/08/2019 7:18 am
Henry Casson
(@henry-casson)
Support response from William Holm. He starts by suggesting factory reset and reflash firmware even if that was done recently.
Postato : 21/08/2019 4:50 pm
