RPM of rear fan not in range!
Hello
Sorry for my english, i am spanish.
Today I got the coveted sl1, unfortunately, when doing the "wizard" has given an error "RPM of rear fan not in range", I tried to disassemble the fan, observe it and have done several tests, removing the particulate filter , with orange lid open, closed, etc ...
I have passed the "wizard" and I have made a calibration, when I started printing a test piece it has given me again the error that the back fan does not work, at the moment the fan is working and the impression I am doing.
Any idea what it could be?
the complete error :
Please check if the fan is connected correctly
RPM data: [1111, 1111, 1500, 2142, 2307, 2000, 1666, 1250] avg 1635
RE: RPM of rear fan not in range!
Let me join you. I am stuck at exactly the same error, after boasting about my construction ability. In my case the average speed is only 1450 or so. I did the same troubleshooting as you did.I note that the advanced settings show a rear fan speed of 1000. I have whined to info@, but have not yet had a reply
Retired doc, should have been an engineer.
info@.... takes a while to respond...
Live chat is usually more responsive
You can find Live Chat, on the Eshop page, bottom right hand corner
Had a reply from support and conversation is ongoing.
Hello Henry
Any support response? I'm out now and I can't contact.
My printer is not in kit, it is completely assembled by prusa
Support response from William Holm. He starts by suggesting factory reset and reflash firmware even if that was done recently.
