					                		Resin Tank Screws Stripping - Hardware, firmware and software help                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-sl1-hardware-firmware-and-software-help/resin-tank-screws-stripping/</link>
                <lastBuildDate>Mon, 15 Jun 2026 02:07:14 +0000</lastBuildDate>
                        <title>RE: Resin Tank Screws Stripping</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-sl1-hardware-firmware-and-software-help/resin-tank-screws-stripping/#post-660731</link>
                        <pubDate>Sun, 18 Jun 2023 07:39:44 +0000</pubDate>
                        <description><![CDATA[thanks for the suggestion about torque! that has helped me using the provided screws better too]]></description>
                        <content:encoded><![CDATA[<p>thanks for the suggestion about torque! that has helped me using the provided screws better too </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-sl1-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Kristan</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-sl1-hardware-firmware-and-software-help/resin-tank-screws-stripping/#post-660731</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-sl1-hardware-firmware-and-software-help/resin-tank-screws-stripping/#post-659602</link>
                        <pubDate>Thu, 08 Jun 2023 23:40:06 +0000</pubDate>
                        <description><![CDATA[I wonder if the Prusa-supplied screws are inferior in some way?  I&#039;d be inclined to try quality screws from someone like McMaster-Carr (if you are in the States).And I&#039;d probably torque them...]]></description>
                        <content:encoded><![CDATA[<p>I wonder if the Prusa-supplied screws are inferior in some way?  I'd be inclined to try quality screws from someone like McMaster-Carr (if you are in the States).</p><p>And I'd probably torque them to commonly recognized values for that type of screw.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-sl1-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>MikeH</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-sl1-hardware-firmware-and-software-help/resin-tank-screws-stripping/#post-659602</guid>
                        <title>Resin Tank Screws Stripping</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-sl1-hardware-firmware-and-software-help/resin-tank-screws-stripping/#post-659449</link>
                        <pubDate>Wed, 07 Jun 2023 19:42:09 +0000</pubDate>
                        <description><![CDATA[Anyone else have issues with the wee torx screws that go around the metal piece to install the FEP? I have two tanks and several screws on one are stripped, the screws on the other (newer) a...]]></description>
                        <content:encoded><![CDATA[<p>Anyone else have issues with the wee torx screws that go around the metal piece to install the FEP? <br /><br /></p><p>I have two tanks and several screws on one are stripped, the screws on the other (newer) are still working but are really difficult to get in/out. <br /><br /></p><p>Anyone else had this? Or has anyone replaced the screws with a different type? <br /><br /></p><p>Thanks</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-sl1-hardware-firmware-and-software-help/resin-tank-screws-stripping/#post-659449</guid>
