Off-time in PrusaSlicer 2.0
Flaviu
(@flaviu)
I am using an Anycubic Photon and their Slicers are using an so called "off-time". It is a very important setting for the print quality. I can not find that setting in the PrusaSlicer 2.0. Am I blind? Is that setting not required for the SL1?
Postato : 06/07/2019 9:43 am
BlueboyX
(@blueboyx)
RE: Off-time in PrusaSlicer 2.0
In the SL1 that setting is in the firmware, so I am not sure where/if it can be found in the PrusaSlicer... 🙁
Postato : 06/07/2019 8:12 pm
Blargedy
(@blargedy)
the only way to increase the off time I've been able to find is to increase the tilt time. I was looking for the same thing, and couldn't find it, so it isn't just you. Increasing the off time on our photons increases the print quality drastically, so I'd be eager to see this feature implemented.
Postato : 30/08/2019 5:07 pm
JohnF
(@johnf)
What does the feature do?
Postato : 04/09/2019 12:45 am
Hi John,
The Anycubic Photon has a different 'Motion' to the Prusa Sl1
where the Prusa Tilts the display and vat as the bed moves up a lyer in height, I believe the Photon raises the print surface a distance plus one layer height, to peel the print off the FEP and then returns the build plate by the peel distance, resulting in the build plate being a layer higher, and I believe:-
Off time is actually how long the the build plate rests after splitting from each layer. Just so you know, the plate actually takes 6.5 seconds per layer to rise and lower with a 1 second wait time.  (ref. dmgdispenser / Reddit)
Postato : 04/09/2019 12:56 am
Blargedy
(@blargedy)
Posted by: joan.t
you are correct in this.
This is incorrect. The off-time includes the movement time.
Despite the SL1 tilting at the same time, there is no option to add a delay between moving back to ready-to-UV-mask and turning the UVLEDs on. Letting the resin rest and fully polymerize is quite important and has a drastic effect on the quality of a print.
-Berni
Postato : 04/09/2019 2:02 am
JohnF
(@johnf)
Thanks, I was wondering how slowing things down affected print quality.
Postato : 04/09/2019 3:36 am
