					                		Layer Time less than 1s - Hardware, firmware and software help                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-sl1-hardware-firmware-and-software-help/layer-time-less-than-1s/</link>
                <lastBuildDate>Fri, 15 May 2026 10:38:00 +0000</lastBuildDate>
                        <title>RE: Layer Time less than 1s</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-sl1-hardware-firmware-and-software-help/layer-time-less-than-1s/#post-666842</link>
                        <pubDate>Tue, 01 Aug 2023 12:22:24 +0000</pubDate>
                        <description><![CDATA[It seems that you can change the minimum time limit (you need to set prusa slicer in advanced mode).In the Printer Settings --&gt; Exposure --&gt; Minimum exposure timeHowever, I do not know...]]></description>
                        <content:encoded><![CDATA[<p>It seems that you can change the minimum time limit (you need to set prusa slicer in advanced mode).<br />In the Printer Settings --&gt; Exposure --&gt; Minimum exposure time<br /><br />However, I do not know if the 1s limit is set for a mechanical reason also (maybe to limit the go back and forth speed which could reduce the life of the machine, or to avoid vibrations). <br /><br />So it is possible to work it around, but maybe you will face some problems. <br /><br />Another alternative is reducing the layer thickness keeping the same time. The resolution will increase, but also the printing will take much longer. </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-sl1-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Mateus Mota Morais</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-sl1-hardware-firmware-and-software-help/layer-time-less-than-1s/#post-666842</guid>
                        <title>Layer Time less than 1s</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-sl1-hardware-firmware-and-software-help/layer-time-less-than-1s/#post-664672</link>
                        <pubDate>Tue, 18 Jul 2023 14:10:21 +0000</pubDate>
                        <description><![CDATA[I&#039;ve a very reactive resin that needs a short cure time but I can&#039;t set the layer time to less than 1s in prusa slicer.Does anyone know a work around?or is this a physical limit? Thanks in a...]]></description>
                        <content:encoded><![CDATA[<p>I've a very reactive resin that needs a short cure time but I can't set the layer time to less than 1s in prusa slicer.</p><p>Does anyone know a work around?</p><p>or is this a physical limit?</p><p> </p><p>Thanks in advance for any help!</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-sl1-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Aaron</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-sl1-hardware-firmware-and-software-help/layer-time-less-than-1s/#post-664672</guid>
