How hard would it be to set the SL1 to use ELEGOO Water Washable 3D Printer Rapid Resin
KLAUS
(@klaus-3)
Hi I am thinking of getting a SL1 and am wondering how hard would it be for me to set the machine to use this water washable 405 nm resin?
What settings or other changes would I need to do?
Thanks
ELEGOO Water Washable 3D Printer Rapid Resin LCD UV-Curing Resin 405nm Standard Photopolymer Resin for LCD 3D Printing
https://www.amazon.com/ELEGOO-Washable-UV-Curing-Standard-Photopolymer/dp/B07X34Z9SC/ref=sr_1_3?dchild=1&keywords=Water-Washable%2BResin&qid=1602040905&s=industrial&sr=1-3&th=1
Veröffentlicht : 07/10/2020 3:31 am
gnat
 gnat
(@gnat)
RE: How hard would it be to set the SL1 to use ELEGOO Water Washable 3D Printer Rapid Resin
Not hard at all. The SL1 has a really cool resin calibration test ( https://help.prusa3d.com/en/article/sl1-resin-calibration-object_112182) to help you figure out your best layer times for 0.5mm layers.
I'm having trouble with the object printing at a slant (though I printed a miniature and it was fine in that regard...). The above pic is the Elegoo water washable grey. Looks like 9.0s or 9.5s per layer are good, but really anything between 7 and 9.5 looked good.
I copied the Prusa Tough Grey profile for both 0.05 and 0.025 layers and bumped the layer times by .5s. I'm currently running with a really high base layer time (60s per the bottle), but I think I can drop that still. The 0.025 print (right, the left was from my MK3S) came out great other than issues related to how I positioned it.
MMU tips and troubleshooting
Veröffentlicht : 07/10/2020 5:42 pm
KLAUS
(@klaus-3)
@gnat
Hi Gnat, thanks for that reply about the water washable resin.  Do you think that the water washable resin is water soluble enough that a stirring machine like the Prusa CW1 would clean the build plate and the print?  Thanks
Veröffentlicht : 10/10/2020 6:43 pm
gnat
 gnat
(@gnat)
Posted by: @bruce-h7
@gnat
I haven't used another cleaning medium so I cannot compare results, but the above pics are parts that were run through the CW1 with just plain water and no scrubbing. In both cases the print had finished roughly 5 hours before I got them in the wash (finished over night), so most of the residual resin had dripped off naturally.
So far I've been happier with the resin than I have been for the printer itself...
Veröffentlicht : 10/10/2020 7:11 pm
