First Start Calibration wont finish, stuck on Bed Tilt Timing Calibration at end of the calibration sequence. (easy solution)
Dexter
(@dexter-2)
Just received my SL1S and had trouble completing the First Start Calibration because, after the last step, it would go into a bed tilt timing calibration cycle that would never complete. When canceling, the message that pops up is that the calibration process will not be completed if the step is skipped.
Solution, just ignore it and update the firmware.
After updating, you will be redirected to recalibrate. At the end, you'll notice the tilt bed timing calibration cycle no longer exists.  The process would have been a lot easier, especially time saving, if that was the first step listed in the set up guidelines. Had to post this because I wasted a lot of time just following the set up guide. before downloading the firmware update, and the customer service chat kep asking me to send them pictures and videos without suggesting the update first.
Opublikowany : 14/03/2025 5:46 pm
1 ludzie polubili
