Cant delete a file
JPMakesStuff
(@jpmakesstuff-2)
Cant delete a file
So I uploaded a file via PrusaSlicer that somehow didn't have any layers (still trying to figure that out, cause it did, but whatever)
Moved it around, uploaded again, same filename, PrusaSlicer says it can't cause file exists, use printer to delete file.
Fine, go to printer webpage, load bad file, can't says "The project must have at least one layer" and doesn't "load" it so I can't get to the delete button, rather it just returns to the file list again.
Back in PrusaSlicer uploaded it again, different name, was able to print that one.
So how do I delete this "bad" file from the printer???
Opublikowany : 06/01/2022 2:01 am
Carsten
(@carsten-2)
RE: Cant delete a file
I think I had that too. I deleted it in the printer.
Carsten
My Prints: https://www.prusaprinters.org/social/15695-carsten/prints
My Employer: https://make-magazin.de
Opublikowany : 22/02/2022 4:18 pm
JPMakesStuff
(@jpmakesstuff-2)
Video showing how "bad" files do not give the option to delete anywhere...
Opublikowany : 03/05/2022 3:30 pm
tsamisa
(@tsamisa)
I got the same problem on my SLS with 1.7 firmware. Anyone got a solution for this?
Opublikowany : 28/08/2022 4:28 pm
