					                		Calibration data seems lost FW 1.8.0 - Hardware, firmware and software help                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-sl1-hardware-firmware-and-software-help/calibration-data-seems-lost-fw-1-8-0/</link>
                <lastBuildDate>Thu, 11 Jun 2026 16:50:22 +0000</lastBuildDate>
                        <title>Calibration data seems lost FW 1.8.0</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-sl1-hardware-firmware-and-software-help/calibration-data-seems-lost-fw-1-8-0/#post-790977</link>
                        <pubDate>Thu, 30 Apr 2026 19:46:26 +0000</pubDate>
                        <description><![CDATA[HiI made SL1S calibration using the printer wizard.I printed a test model and the result was great.I took out USB drive to my pc and copy another model.When i come back to the printer the po...]]></description>
                        <content:encoded><![CDATA[<p>Hi<br />I made SL1S calibration using the printer wizard.<br />I printed a test model and the result was great.<br />I took out USB drive to my pc and copy another model.<br />When i come back to the printer the power was off (maybe asome Time Out) so i press the front button and the printer went ON.<br />I put the USB drive it the printer and stated to print the new model.<br />The printer start hitting the platform against the bottom of the tank and made a lot of knocking noise. It seems that it is not calibrated at all.<br />I stop the print and use calibrate wizard again. I noticed that the Tilt start value wasnt as i set it up in the last calibration procedure. So i calibrate again and print with no problem/<br />It happened to me after every print, after power shut down.<br />Why the calibration data lost?<br />Any knowladge or solution for that?<br />Thanks</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-sl1-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>YZ</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-sl1-hardware-firmware-and-software-help/calibration-data-seems-lost-fw-1-8-0/#post-790977</guid>
