Access to even more specific layer settings, or G-Code Access?
cpritchard
(@cpritchard)
I'm wondering if it's possible to edit specific layer exposure times, e.g. layer 1 - 10000ms, layer 2 - 24000ms, layers 3 and up - 12000ms.
I'm also curious if it's possible to edit the power/speed of the tilt mechanism.
I've found some slicers for other printers(chitubox, creation workshop) , and they export with a gcode file that can be easily edited, but from what I can tell, the prusa sl1 does not work the same way. All I've found was a config file that gives me the same option as the prusa slicer.
The reason we need more specific control is that the company I work for develops ceramic resins for 3d printing, and we need a high level of control over the printer to be able to perform the tests and builds we need.
Any help/advice would be greatly appreciated!
Posted : 18/09/2019 7:58 pm
