UV LIGHT COMING OUT OF CW1
kdude
(@kdude)
Hi, am I the only one that can see a lot of UV l ight coming under the lid of the CW1, and if so, how bad is it to look at it? because if I want to look at the timer I don't really have a choice and I can see the light.
Thanks,
Opublikowany : 31/03/2020 3:24 am
gruagach
(@gruagach)
RE: UV LIGHT COMING OUT OF CW1
Posted by: @kdude
Thanks,
If you can see it, it’s not in the UV range.
Opublikowany : 31/05/2020 9:14 am
Lichtjaeger
(@lichtjaeger)
@robb-lincoln
405nm is between UV and "black light". So you can see the light of those curing stations.
@kdude
It is harmful if you look at it for some time. I have bought safety goggles with UV filter for this reason. (And also a 405nm flashlight for curing splashes, stains and waste)
I wanted to construct a frame to put inside the CW1 to seal the gap, but I haven't gotten around to it yet.
Opublikowany : 31/05/2020 10:03 am
1 ludzie polubili
WarandPeace
(@warandpeace)
Try loosening the hinges for the top and readjust the cover.  Tighten and give it a test...  You should only see a very slim line of light escaping.
Opublikowany : 07/06/2020 5:07 am
