SL1 and a hard resin
Rob Meades
(@rob-meades)
I need to print relatively small (~15 mm diameter) gears in my SL1 and, being gears that will rub together, I need the finished product to be as hard as possible.  I have the white ABS-like resin, which does not appear to be so hard, and the transparent resin, from which I have several printed parts that are a few years old lying around that seem to be better from a hardness perspective.
Are there any other resins for use in the SL1 that people would recommend for hardness?
Publié : 13/10/2024 8:55 pm
tsamisa
(@tsamisa)
RE: SL1 and a hard resin
Im using Siraya tech build with fairly good results.
https://siraya.tech/products/build-resin-drillable-precision-printing
Publié : 17/10/2024 4:57 am
Rob Meades
(@rob-meades)
That's great, thanks, and available from Amazon in the UK.  I'll give it a try.
Publié : 17/10/2024 7:13 am
Rob Meades
(@rob-meades)
FYI, that resin worked excellently, thanks for the recommendation.  Here is the printed output in action:
Publié : 20/10/2024 1:01 pm
tsamisa
(@tsamisa)
Gald to be of help 🙂 Honestly i really like moving gears.
Publié : 20/10/2024 7:01 pm
1 personnes ont aimé
