					                		Mixing resins? What ratio do you use? - General discussion, announcements and releases                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-sl1-general-discussion-announcements-and-releases/mixing-resins-what-ratio-do-you-use/</link>
                <lastBuildDate>Wed, 17 Jun 2026 10:54:35 +0000</lastBuildDate>
                        <title>RE: Mixing resins? What ratio do you use?</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-sl1-general-discussion-announcements-and-releases/mixing-resins-what-ratio-do-you-use/#post-348211</link>
                        <pubDate>Fri, 15 Jan 2021 12:06:23 +0000</pubDate>
                        <description><![CDATA[@lichtjaegerThank you!That video certainly is a nice example of someone putting some effort in experimenting with mixing resin *and* sharing the results in a very useful and compact manner!]]></description>
                        <content:encoded><![CDATA[<p>@lichtjaeger</p><p>Thank you!<br /><br />That video certainly is a nice example of someone putting some effort in experimenting with mixing resin *and* sharing the results in a very useful and compact manner!</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-sl1-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>Wilko</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-sl1-general-discussion-announcements-and-releases/mixing-resins-what-ratio-do-you-use/#post-348211</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-sl1-general-discussion-announcements-and-releases/mixing-resins-what-ratio-do-you-use/#post-347512</link>
                        <pubDate>Thu, 14 Jan 2021 14:02:40 +0000</pubDate>
                        <description><![CDATA[🤔If you use a usual flex resin instead of Flex100 you might need a 1:1 ratio or even more flex. One key factor is the shore hardness. Flex100 has 10.5D, flexible resins between 60D and 82D a...]]></description>
                        <content:encoded><![CDATA[<p>🤔</p><p>If you use a usual flex resin instead of Flex100 you might need a 1:1 ratio or even more flex. One key factor is the shore hardness. Flex100 has 10.5D, flexible resins between 60D and 82D and standard resins 92-94D.</p><p>IMO 85-87D are good values for miniatures.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-sl1-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>Lichtjaeger</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-sl1-general-discussion-announcements-and-releases/mixing-resins-what-ratio-do-you-use/#post-347512</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-sl1-general-discussion-announcements-and-releases/mixing-resins-what-ratio-do-you-use/#post-347506</link>
                        <pubDate>Thu, 14 Jan 2021 13:50:53 +0000</pubDate>
                        <description><![CDATA[Yes, experience values.I use Monocure Flex100 in combination with Prima Value Standard, Prusa Tough and Monocure Rapid resins.Some referenceMonocure does also offer pigment sets to dye your ...]]></description>
                        <content:encoded><![CDATA[<p>Yes, experience values.</p><p>I use Monocure Flex100 in combination with Prima Value Standard, Prusa Tough and Monocure Rapid resins.</p><p>Some reference:</p><p>https://youtu.be/smebtj-tqiY</p><p>PS: Monocure does also offer pigment sets to dye your resins.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-sl1-general-discussion-announcements-and-releases/mixing-resins-what-ratio-do-you-use/#post-347506</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-sl1-general-discussion-announcements-and-releases/mixing-resins-what-ratio-do-you-use/#post-347494</link>
                        <pubDate>Thu, 14 Jan 2021 13:14:21 +0000</pubDate>
                        <description><![CDATA[@lichtjaegerDanke!Is the 25-30% range based on experimenting?May I ask what brands of normal and flexible resin you combine?I have Prusa, Anycubic and Sunlu resins, and I&#039;m not sure right no...]]></description>
                        <content:encoded><![CDATA[<p>@lichtjaeger</p><p>Danke!<br /><br />Is the 25-30% range based on experimenting?<br />May I ask what brands of normal and flexible resin you combine?<br />I have Prusa, Anycubic and Sunlu resins, and I'm not sure right now what brand the flexible resin is that I have ordered.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-sl1-general-discussion-announcements-and-releases/mixing-resins-what-ratio-do-you-use/#post-347494</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-sl1-general-discussion-announcements-and-releases/mixing-resins-what-ratio-do-you-use/#post-347389</link>
                        <pubDate>Thu, 14 Jan 2021 09:52:25 +0000</pubDate>
                        <description><![CDATA[25-30% Flex and the print is way less brittle and still hard.]]></description>
                        <content:encoded><![CDATA[<p>25-30% Flex and the print is way less brittle and still hard.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-sl1-general-discussion-announcements-and-releases/mixing-resins-what-ratio-do-you-use/#post-347389</guid>
                        <title>Mixing resins? What ratio do you use?</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-sl1-general-discussion-announcements-and-releases/mixing-resins-what-ratio-do-you-use/#post-347365</link>
                        <pubDate>Thu, 14 Jan 2021 08:53:49 +0000</pubDate>
                        <description><![CDATA[I&#039;ve seen several posts with people mentioning that they have mixed resins, both to get a different elasticity or colour. What kind of ratio do you use between flexible and normal resin to g...]]></description>
                        <content:encoded><![CDATA[<p>I've seen several posts with people mentioning that they have mixed resins, both to get a different elasticity or colour. <br />What kind of ratio do you use between flexible and normal resin to get the result of a non brittle print? What is that ration dependent on: harness rating?<br />I have ordered a kg of flexible resin, but considering the price per kg of that stuff compared to normal resin, it would be nice to not use more of it than is absolutely necessary.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-sl1-general-discussion-announcements-and-releases/mixing-resins-what-ratio-do-you-use/#post-347365</guid>
