Cleaning the print platform
After serveral prints with the SL1S the surface of the print platform is not uniform. I did clean it every time after the print.You might notice some blue points from a blue Prusa flex resin. There are other areas on the platform that have a different feeling, I can't describe it in a better way.
What I did not do by now is like recommended in the article: https://help.prusa3d.com/article/sl1-sl1s-maintenance_1951 to use a metal spatula. I could use one from my iFixit Toolkit. What I also thought is using a sandpaper (100/200/400) Bu I don't know if I damage it completely then.
Do you have any additional idea ? Printing works, but sometimes when I have several parts on the platform on does not stick on the platform (coasters).
Postato : 26/10/2024 5:03 pm
