Accuracy of objects.
Hello
I would like to know if this 3d printer has any accuracy advantages compared to the other cheaper ones(elegoo mars, phrozen sonic etc.) and what is the accuracy of it.
RE: Accuracy of objects.
Are you asking for the dimension accuracy of printing mechanical parts that have to fit together? Because I'd be interested in this as well for the SL1S.
With the Anycubic Photon-S I don't have good experiences. Everything in the z-axis is pulled by the layer separation. It's really tough to get accurate parts. Even the Form3+ suffers from that if supports are not well placed. Other than that the details are great on almost all those machines.
Resin matters for dimensional accuracy. Every manufacturer is different, best to check reviews/community posts on certain resins.
I have been using Bluecast Xone V2 for jewellery where my tolerances are usually in the 0.01 mm area. I have found this resin, although specific to casting, to be extremely accurate.
This.
Most resins are quite prone to warping. Every resin behaves differently and it depends on the design as well.
