					                		Print display levelling and calibration - tilted down every time? - Assembly and first prints troubleshooting                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-sl1-assembly-and-first-prints-troubleshooting/print-display-levelling-and-calibration-off-every-time/</link>
                <lastBuildDate>Wed, 11 Mar 2026 16:27:07 +0000</lastBuildDate>
                        <link>https://forum.prusa3d.com/forum/original-prusa-sl1-assembly-and-first-prints-troubleshooting/print-display-levelling-and-calibration-off-every-time/#post-624321</link>
                        <pubDate>Sat, 22 Oct 2022 15:06:55 +0000</pubDate>
                        <description><![CDATA[I think Syraya and Prusa resin bottle both recommend to print above 27 C
I have both my SL1S and CW1S on a heating pad to MAINTAIN warmth in my otherwise cold basement.
I wouldn&#039;t want to ...]]></description>
                        <content:encoded><![CDATA[<p>I think Syraya and Prusa resin bottle both recommend to print above 27 C</p>
<p>I have both my SL1S and CW1S on a heating pad to MAINTAIN warmth in my otherwise cold basement.</p>
<p>I wouldn't want to work in 27+ temperatures anyway, but I think most resins work best above 28 C.</p>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-sl1-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>2regburgessearthlink.net</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-sl1-assembly-and-first-prints-troubleshooting/print-display-levelling-and-calibration-off-every-time/#post-624321</guid>
                        <title>RE: Print display levelling and calibration - tilted down every time?</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-sl1-assembly-and-first-prints-troubleshooting/print-display-levelling-and-calibration-off-every-time/#post-607930</link>
                        <pubDate>Wed, 25 May 2022 19:02:03 +0000</pubDate>
                        <description><![CDATA[Me again - I actually got my first test print to work! Key appears to have been using the CW1S to pre-heat the resin to around 34 °C]]></description>
                        <content:encoded><![CDATA[<p>Me again - I actually got my first test print to work! Key appears to have been using the CW1S to pre-heat the resin to around 34 °C</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-sl1-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>boatoab</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-sl1-assembly-and-first-prints-troubleshooting/print-display-levelling-and-calibration-off-every-time/#post-607930</guid>
                        <title>Print display levelling and calibration - tilted down every time?</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-sl1-assembly-and-first-prints-troubleshooting/print-display-levelling-and-calibration-off-every-time/#post-607914</link>
                        <pubDate>Wed, 25 May 2022 15:08:07 +0000</pubDate>
                        <description><![CDATA[Hi all, new to the forum and to the SL1S, not had a successful print yet - usually no adhesion to the platform at all, or if there is, then just for a few patches, which then give up. I&#039;ve s...]]></description>
                        <content:encoded><![CDATA[<p>Hi all, new to the forum and to the SL1S, not had a successful print yet - usually no adhesion to the platform at all, or if there is, then just for a few patches, which then give up. I've seen all the tips regarding tightening the cantilever screw, slowing the print down, all that good stuff - as yet to no avail. One thing I have noticed is that each time I calibrate the machine, when it comes to levelling the print display against the tank base, it is always tilted down at the front each time. Is this normal? I mean, does the calibration cycle always set the print display to be tilted down at the front so that I always have to nudge it up to level? Or should it actually return to the position I last calibrated it at?</p>
<p>Would be good to know if the UV LED and display are having positioning problems or not!</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-sl1-assembly-and-first-prints-troubleshooting/print-display-levelling-and-calibration-off-every-time/#post-607914</guid>
