Printable Temperature Towers Printing at Default Temp
nzxela
(@nzxela)
I have tried downloading a number of Printables.com temperature towers including Temperatur-Tower-MK3_PETG_250-230_1h22m.gcode
I copy the file to my SD Card and the entire test prints at 240?
My printer has worked well for 3 years doing hundreds of prints and has been upgraded to MK3.5s along. It's on the latest firmware.
Most towers like the one above are too big and take way to long to print. Please keep test pieces small. The test strips for layer calibration I use are only 9cm long and 5mm wide as that's all you need. 15 strips does the job.
I checked the code in notepad and the M104 codes are all there.
What else can I check?
Everyone will want to do temperature towers so it would save Prusa users a lot of time if there was a Printables page for MK3 tests, fast, small temp towers and first layer calibration tests. Every other aspect of the Prusa support and documentation is excellent and why I will be upgrading to MK4 in the future.
Regards
Alex
Postato : 28/03/2024 8:57 pm
lambert
(@lambert-2)
RE: Printable Temperature Towers Printing at Default Temp
Hello,
made my temptowers yesterday and that worked fine.
I used this tutorial
greetings
Lambert
Postato : 28/03/2024 9:25 pm
