					                		belt tension app - Hardware, firmware and software help                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-mk3-5-hardware-firmware-and-software-help/belt-tension-app/</link>
                <lastBuildDate>Fri, 08 May 2026 14:06:29 +0000</lastBuildDate>
                        <title>RE: belt tension app</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-mk3-5-hardware-firmware-and-software-help/belt-tension-app/#post-710431</link>
                        <pubDate>Thu, 09 May 2024 13:40:26 +0000</pubDate>
                        <description><![CDATA[any of the older MK3 series, or MK4 would work just fine.]]></description>
                        <content:encoded><![CDATA[<p>any of the older MK3 series, or MK4 would work just fine. </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-mk3-5-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Lynn</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-mk3-5-hardware-firmware-and-software-help/belt-tension-app/#post-710431</guid>
                        <title>belt tension app</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-mk3-5-hardware-firmware-and-software-help/belt-tension-app/#post-710428</link>
                        <pubDate>Thu, 09 May 2024 12:54:17 +0000</pubDate>
                        <description><![CDATA[When I need to check the belt tension X and Y I can use the Prusa belt tension app.There are 4 machine choices but not the mk3.5 and 3.9.I assume for those two I can use the Prusa Mk3s?Chris]]></description>
                        <content:encoded><![CDATA[<p>When I need to check the belt tension X and Y I can use the Prusa belt tension app.</p><p>There are 4 machine choices but not the mk3.5 and 3.9.</p><p>I assume for those two I can use the Prusa Mk3s?</p><p>Chris</p><p> </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-mk3-5-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>ChrisG</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-mk3-5-hardware-firmware-and-software-help/belt-tension-app/#post-710428</guid>
