Original Prusa i3 MK3S/+ to MK3.5 upgrade kit is out.
[Sticky] Original Prusa i3 MK3S/+ to MK3.5 upgrade kit is out.
Stránka 1 / 2
Same Old Shane
(@same-old-shane)
Member Admin
Its now out, go check out all the details here on our eshop
https://www.prusa3d.com/en/product/original-prusa-i3-mk3s-to-mk3-5-upgrade-kit-2/
Supercharge your MK3S and MK3S+!
With the introduction of the MK4, we were looking for ways to bring its features to our proven workhorse, and the MK3.5 upgrade is the answer. It’s the easiest and most affordable option to print two times faster and expand the capabilities of your MK3S/+ 3D printer!
Enjoy benefits such as super-fast printing with the addition of Input Shaper, sending files wirelessly to your machine without using Raspberry Pi, and navigating the printer’s menus faster than ever before with the new large LCD. The upgrade is straightforward to install and with our detailed assembly guide and 3D printing handbook, you’ll be up to speed in no time!
High-speed printing with ease
As a part of the upgrade package, you will receive our new 32-bit embedded xBuddy to expand your 3D printer’s capabilities. The addition of Input Shaper and Pressure Advance brings a massive boost to your MK3S/+, allowing you to print more than twice as fast and with the same level of quality. The prints that would be otherwise running the entire night can be finished in just a few hours.
Prusa Connect and easy networking
With the MK3.5 upgrade, you also receive an easy way to connect your printer to your network - both wired and wireless. Add the MK3.5 to Prusa Connect, our internally developed remote print management solution, and start sending print files to your printer without the need to deal with USB drives. G-code streaming enables you to start printing mere seconds after you upload the file to the Prusa Connect cloud. However, Prusa Connect can do even more. Check out our article to learn all about it!
Plenty of quality-of-life improvements
It’s time to replace the old segmented LCD with a brand new one. This 3.5’’ color LCD gives you much better control over your printer. See print file previews, read detailed instructions, or scan QR codes - using the printer is now much more convenient. With the new electronics and the new LCD, you can now use standard USB flash drives for storing G-codes, and you can also use a USB drive to flash new firmware (but you can also do it remotely via Prusa Connect). You can customize which information is displayed at all times in the footer of the LCD screen.
Easy to install
The MK3.5 upgrade is easy to install - we’re providing detailed assembly instructions in seven languages and an updated 3D printing handbook to get you started. You don’t have to worry about getting stuck. Everything has been thoroughly tested in-house. You’ll start printing in no time!
PSU & Heatbed info
Before you order the upgrade, please check which PSU your printer came with and which version of the heatbed connector is installed. This is important for correct compatibility with the upgrade. Depending on the selected options, we can send you additional components to ensure compatibility with the upgrade.
psu comparison foto
Which PSU does your printer have?
  • Black PSU - you are all good
  • Silver PSU - you will need to add a compatible wiring harness or a black PSU (in the configuration box above)
heatbed comparison foto
How many screws does your heatbed have?
  • 2+3 screws (power cable connected with screws) - you are all good
  • 2+1 screws (power cable soldered) - replacing the bed will be necessary
Be sure to choose the correct options in the top right menu before you place your order!
Package Includes
This product is supplied as a kit - you must assemble it yourself!
Printed parts are NOT included! Please print them before you disassemble your MK3S/+! The filament is included in the upgrade package.
Important: The black injection-molded spool holder is not part of the upgrade package. If your printer didn't come with it (early revisions of MK3), you can purchase it here.
This product includes:
  • 32-bit xBuddy board (same as MK4)
  • Metal xBuddy case (and cover)
  • xLCD screen + cables (same as MK4)
  • Cable adapters for your current extruder and heatbed
  • Expansion joints for Heatbed
  • Fasteners and other accessories
  • Filament for printable parts
Parts kept from your MK3S/MK3S+
  • Extruder with V6 hotend
  • Frame and extrusions (the new MK4 has just a different look)
  • PSU* (same wattage/voltage as MK4)
  • Heatbed MK52 24V (thermistor and power cables will be changed)
  • X/Y/Z/E motors
  • X/Y/Z rods and bearings
Shane (AKA FromPrusa)
Napsal : 05/02/2024 6:56 pm
CW
 CW
(@cw-3)
Have you heard any estimate when the mmu3 cable will be available for the MK3. 5?
Thanks!
Napsal : 05/02/2024 8:20 pm
MarkusRe a skoro se líbí
RE: Original Prusa i3 MK3S/+ to MK3.5 upgrade kit is out.
I just ordered two of them.  Thanks.
Napsal : 05/02/2024 9:19 pm
BM
 BM
(@bm-2)
I ordered mine as well. I am looking forward to see how much we still can squeeze out of this good old MK3!
Napsal : 08/02/2024 6:44 pm
the product information suggests that A Mk3 is not part of the upgrade path
Napsal : 08/02/2024 7:53 pm
John
 John
(@john-6)
I look forward to seeing the feedback of the early adopters in particular the speed increases.
I was initially bummed as I has just bought the mk3s+ upgrade when the mk3.x upgrades were first announced but the 3.5 update with a significant speed boost looks reasonable value.
i3 Mk3 [aug 2018] upgrade>>> i3MK3/S+[Dec 2023]
Napsal : 08/02/2024 8:38 pm
BM
 BM
(@bm-2)
Right..., I have a MK3s. but interesting to refresh this point.
I meant Mk3 serie per position to mk4 😉
Napsal : 08/02/2024 9:29 pm
If you have an early mk3S, like I did,
you may have a heatbed with soldered connections, and a silver power supply
When I upgraded to Mk3.9,
I needed a new heatbed with screw attached, power cables, an earth bonding wire for the power supply and a different Power Panic wire.
Later Mk3X printers have the Black Delta Power supply, and  the screw connected  power wires on the heat bed as standard.
I expect the Mk3.5  upgrade will need to address these same issues
Napsal : 08/02/2024 9:40 pm
Qbnflaco
(@qbnflaco)
Looks like mine didn't come with the wiring harness even though they sent out a questionaire last summer asking about your heatbed and power supply. I guess I need to buy a new heatbed, but it doesn't look like there's any way to buy the wiring harness seperately.
Napsal : 12/02/2024 10:42 pm
Owens2303
(@owens2303)
Can I order the xyz stepper motors and fit them to the mk3:5 and will the just plug into motherboard and work?
Napsal : 26/02/2024 7:21 am
How would you use a harness?  The Mk3 is soldered to the bed?
I have an Mk3 that I already replaced the bed and it came with the Harness for that.
Posted by: @qbnflaco
One issue that I might have run into is the only Bondtech extruders require custom firmware.   Reportedly, I will have to void my warranty if I use them.
This post was modified před 10 months by cwbullet
Napsal : 26/02/2024 11:49 am
Boulder
(@boulder)
I own a MK3s and want to upgrade to Mk3.5 . Should i upgrade to MK3s+ first and then to Mk3.5? Will i gain anything in terms of quality or speed?
Napsal : 29/02/2024 10:41 am
Quality?  I can't speak for that.  Speed?  None.
Mk3S+ has improved bed clips and the SuperPinda is temperature independent and high quality sensor.
Posted by: @boulder
Napsal : 29/02/2024 11:00 am
Boulder
(@boulder)
If so there is no reason to invest another 50 euros to the Mk3,5 upgrade kit.
Napsal : 29/02/2024 12:25 pm
Yveske
(@yveske)
There is an upgrade path from MK3.9 to MK4, will there be an upgrade path from MK3.5 to MK3.9/MK4 ?
Same with MMU2 upgrades, are you stuck when you upgrade to MK3.5 or can it be upgraded further (without duplicates) ?
Having problems with bed adhesion every morning...
Napsal : 29/02/2024 3:02 pm
Jeff
 Jeff
(@jeff)
When I ordered my 3.5 upgrade kit I did not see the additional requirements for the PSU and the heated - can those be ordered separately?  I did not see them listed as available parts - - -
Napsal : 02/03/2024 11:47 pm
Yes, they can.
Posted by: @jeff
Napsal : 02/03/2024 11:59 pm
Jeff
 Jeff
(@jeff)
Where do I go to order them?  I was just on live chat, down to a 16 minute wait when I got kicked out
Napsal : 03/03/2024 12:23 am
John
 John
(@john-6)
Posted by: @jeff
There is a pop down menu for the adds if you need them
Napsal : 03/03/2024 3:30 am
Jeff
 Jeff
(@jeff)
I already have the kit, I just need the heat bed and power supply - the drop down just adds them to the upgrade kit.
Napsal : 03/03/2024 6:09 am
Stránka 1 / 2
