MMU3 over current boot up alarm after resetting MK3.5
mpatl
(@mpatl)
I upgraded my MK3S+ MMU3 to a MK3.5 MMU3 last week and it had been working great for 4 days until today something weird happened.  I had to cancel a print and start another before the filament loaded.  After cancelling it wanted to heat up to unload a non-existent filament so I hit the reset button to reboot.
On reboot I got the MMU over current alarm.  I tried rebooting 4 times and got it everytime so I powered down the printer and went to the forums for a search.  I found the article about MMU overcurrent and the fact that some xbuddy boards appear to be faulty.
I went back to my printer 10 minutes later and it booted up.  I've used it for a whole bunch of multicolour prints since but am worried to ever hit reset.
I contacted support and all they suggested was to reload the firmware and not to worry that if it happens again they will work through it with me and solve it.
Anyone else had this happen or something similar?
Posted : 19/08/2024 4:31 pm
mpatl
(@mpatl)
RE: MMU3 over current boot up alarm after resetting MK3.5
Happened again, but this time the printer crashed on the first bed line of setting up a new steel sheet when I turned the knob.  Restart had MMU error.  Same wait time required and it reboots ok.
Posted : 20/08/2024 12:32 am
mpatl
(@mpatl)
Found this solution on Reddit. User tbachtell states:
I have an MK4 and a Mk3.5, both with MMU3. I use Octoprint on both. I was getting frequent over current errors and it was driving me crazy. I finally tried removing the USB running from the RPi to the xBuddy board and never had another over current error. I pull out the USB connection at the RPi when I turn the printers on. Then I plug it in and everything works perfectly. I reported this to Prusa.
I also have a rpi running OctoPrint attached!  Unplugging the usb cable solves the MMU overcurrent error.  I will report it to Prusa as well if the proble doesn't reoccur for a week.
Posted : 20/08/2024 2:23 am
doomsey
(@doomsey)
This seems to be a known issue, it is discussed over in the Buddy Board software git. https://github.com/prusa3d/Prusa-Firmware-Buddy/issues/3947
I get this error every time if I have Octoprint / USB plugged in, and intermittently (reliably if hot) if not. Prusa has not been willing to support / warranty this and I am unhappy with the situation.
Posted : 20/08/2024 2:43 pm
echo
 echo
(@echo)
I got the same thing. I tried 3 different firmwares. I had just upgraded my MK3 to MK3.5, everything worked fine. Later when I had my printer set up with Octoprint I got Overcurrent MMU. I remembered that some marlin software/motherboards have sometimes problem with USB power. I simply put a tape strip over 5V pin in the USB cable. There is an article about this at Octoprint search for "Put tape on the 5V pin - Why and how"
Posted : 15/10/2024 8:44 pm
echo
 echo
(@echo)
Here is the link
https://community.octoprint.org/t/put-tape-on-the-5v-pin-why-and-how/13574
Posted : 15/10/2024 8:48 pm
Michael Schneider
(@michael-schneider)
I had this issue and Prusa sent me a new xbuddy board. I have not got around to replacing it yet. I've found that I can open the idler cover on my MMU and rotate the idler back and forth quickly and the printer will boot. I believe that generating a small amount of power helps avoid the overcurrent error.
Posted : 27/01/2025 2:50 am
mpatl
(@mpatl)
I guess you got a better service agent than I've gotten on three occassions.  One even tried to blame the MMU3.  Based on your post I will try again.  It is still super annoying.  What did you say to convinced them?
This post was modified 8 months ago by mpatl
Posted : 27/01/2025 5:59 am
Michael Schneider
I didn't have to convince them at all. We did several tests booting the printer with the mmu connected and disconnected. Printer booted fine without the mmu connected so they said that confirmed that there was a problem with the board.
Posted : 28/01/2025 1:46 am
LarGriff
(@largriff)
The issue finally has been properly diagnosed and resolved.  Replace C96 on the xBuddy board with 100nF capacitor.  Prusa has just recently become aware of this but hasn’t yet committed to a course of action.
https://github.com/prusa3d/Prusa-Firmware-Buddy/issues/3947#issuecomment-2665954658
MK4S/MMU3
Posted : 02/03/2025 8:10 am
doomsey
(@doomsey)
I do this type of work professionally, and actually I've done a product recall for a similar problem. (I didn't pick the part! Not my fault! 🤣) They've been dancing around the root cause on the github since I posted, actually, and I was pretty sure it was an oversensitive inrush detection.  Glad someone did the leg work to look carefully at the circuit and prove it. I just never had the patience.
I actually even came up with some fix ideas of my own (the resistor concept, and another where I put a FET switch on the power line direct from the power supply) but never got to it because moving the motor worked 'well enough'
Thanks everyone for giving me some leverage to get a fix.
Posted : 02/03/2025 4:10 pm
PeachMonkey
(@peachmonkey)
The 6.2.3-alpha firmware appears to have solved this for me. I run a MK4S with MMU3 and it no longer screams red on reset.
Posted : 25/03/2025 9:42 pm
