Mk 3.5 configuration for Prusaslicer?
If we are having to use the configurations for the MK 4 for our Mk 3.5, wouldn't it make sense to clone the Mk 4 configurations and name them for the Mk 3.5; at least until the new configs are tested and ready. I'm printing using prusa link and so when I send a sliced file to my printer over wifi, I have to go to that location to override the configuration mismatch. It kinda defeats the purpose of wifi if I have to go to that location anyway just to push a button.
RE: Mk 3.5 configuration for Prusaslicer?
You could comment out, this line in the Printer settings>Custom GCODE>Start gcode
M862.3 P M862.3 P "[printer_model]" ; printer model check; printer model check
Or you could guess what the correct "[printer_model]" ; variable name is, and change that in the printer profile!
Perfect. That worked. Thanks.
Found a setting in the printer's settings menu that disables the check.
Settings > Hardware> GCODE checks.
