First thoughts on Filamentalist auto-rewinder
Page 3 / 3
Jacek
(@jacek-3)
What version for bottom loading  80 and 100mm ?
Ce message a été modifié il y a 7 days par Jacek
MK4s+mmu3 I use a translator
Publié : 20/02/2026 8:03 pm
Rainer
(@rainer-2)
RE: First thoughts on Filamentalist auto-rewinder
I'm not sure what you mean.
Basically, there is the old version, with 80 and 100 mm, or the new version.
You have to be careful when ordering from AliExpress.
If you describe where you want to use it, we might be able to recommend something.
I made the new version in this box.
Publié : 20/02/2026 9:44 pm
Jacek
(@jacek-3)
I have 60 cm wide boxes with front opening. Which version should I use for this setup? I can buy Vileda one-way bearings locally, but they come in three versions:
6/8-angle and smooth
Publié : 21/02/2026 7:27 am
Jacek
(@jacek-3)
Will it print classic versions, or do all elements require scaling for petg?
Publié : 21/02/2026 9:03 pm
Page 3 / 3
