First thoughts on Filamentalist auto-rewinder
Strona 2 / 2
Chris Hill
(@chris-hill)
My Triangle-Lab kit arrived this morning, so I assembled the first of the 80mm rewinders.  I'm hugely impressed - the kit is very nice, the parts all fitted together perfectly, and the rewinder seems like it's going to be just the ticket.
I'm looking forward to trying these out with the MMU3, but I'll have to be patient for a little while longer until the 1m MMU cable that I ordered arrives.
Opublikowany : 16/06/2025 11:16 am
1 ludzie polubili
Chris Hill
(@chris-hill)
RE: First thoughts on Filamentalist auto-rewinder
One last attempt to post the video!
https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/06/94552f02-rewinder.mp4
Opublikowany : 16/06/2025 12:15 pm
Chris Hill
(@chris-hill)
I've built up a 100mm rewinder as well, and now I'm wondering if there's any reason why I shouldn't have gone for 5 of those.  I had assumed that the wider one would be somehow unsuitable for narrower spools, but in fact the gap between the rollers is the same in both versions so the only drawback I can see with the wider one is the extra shelf space that it will take up.  But as luck would have it my reprack shelf has just the right width to take 5x100mm rewinders.
Have I missed something?
Opublikowany : 16/06/2025 1:54 pm
jon
 jon
(@jon-18)
You can use the 100mm wide with narrow spools without problem.
The "mid section" is the same, the real change it's the pulleys are wider.
Opublikowany : 16/06/2025 1:59 pm
2 ludzie polubili
Steve
(@steve-11)
Yeah I went 2x100mm & 3x80mm purely due to space concerns. In hindsight I'd have gone all 100mm but it's fine as is.
One thing I have done recently is introduce a gap in the PTFE of about 75mm to allows me to feed the filament into the MMU easier. It also acts as a sort of Y connector to position 5 that means I can easily introduce a feed from my dryer without swapping PTFE tubes about. Because the dryer cannot auto rewind I've used one of the original buffer cassette wheels behind an Ikea Skadis pegboard.
Opublikowany : 16/06/2025 3:30 pm
1 ludzie polubili
Chris Hill
(@chris-hill)
Posted by: @steve-11
Those are both rather neat ideas.  I'm considering a similar junction point, with a view to making it easier to swap the MMU between a MK4S and the CORE One, although I haven't really thought it through yet.
Opublikowany : 16/06/2025 4:33 pm
I had enough left-over hardware from my first Trianglelabs order for small spools so I just ordered some longer dowels to make a couple of wider spool holders.
After six weeks with the Filamentalist rewinders I couldn't be happier. Not one issue. Given how much time and material I wasted on other rewinders, glad to find something that just works.
Opublikowany : 16/06/2025 5:13 pm
Chris Hill
(@chris-hill)
Yes, it's quite an ingenious design.  I'd like to think that if I'd ever come across the concept of a one-way bearing I might have been able to conceive of something similar, but I'm not convinced I would have!
Opublikowany : 16/06/2025 7:31 pm
jon
 jon
(@jon-18)
yeah, filamentalist is the nuclear option, the last you try, the only you will use forever.
Since I switched to filamentalist all my printers I live happier.
Posted by: @foxrun3d
Opublikowany : 16/06/2025 8:14 pm
1 ludzie polubili
rosic
(@rosic)
I also tried this solution instead of buffer but so far every print failed with filament slip in Nextruder and stoppage in extrusion. I think the issue is with high speed printing with fast extractions where the inertia of the filament roll causes slip in Nextruder gears. Tried multiple settings even decreasing the tension really low but every print with Speed profile for PLA failed. No issues with Prusa buffer.
Opublikowany : 11/08/2025 9:45 am
Chris Hill
(@chris-hill)
Posted by: @rosic
Are the PTFE runs from the rewinders to your printer particularly long?  What is the internal diameter of your PTFE tubes?
If the route from the rewinder involves more friction than it did with the buffers, perhaps it's showing up a slight misadjustment of extruder idler.  Are you sure you have the two screws with springs on them adjusted correctly, as per the instructions?
Second photo on this page: https://help.prusa3d.com/guide/9d-core-one-nextruder-mod_111779#894983
Opublikowany : 11/08/2025 2:16 pm
Rainer
(@rainer-2)
Hello, I'm interested in how this solution performs in continuous use.
I've just discovered a version that combines the cereal boxes I use with the Filamentalist.
I'd be very interested in that.
You can even buy the finished version on Ali.
I read on Reddit about someone who only had 2 or 3 out of 5 still working properly.
What has been your experience?
Opublikowany : 07/12/2025 1:35 pm
jrlebel
(@jrlebel)
i just finished building and installing the filamentalist rewinders in an (un)original drybox. Still have some tuning to do but it works pretty well although I had to revert to a strait through ptfe tube to the extruder. It looks like going through the y splitter was creating too much friction and the MMU would slip not being able to rewind the filament at time. I’ll give it another try later as I like to by-pass the MMU when using ASA, ABS and such. I really only use the MMU for PLA.
IMG_1156
Opublikowany : 08/12/2025 6:27 pm
Rainer
(@rainer-2)
That sounds promising. I've just ordered five kits. But I'm going to install it in these boxes.
I use these Festo connectors when I want to bypass the MMU.
Opublikowany : 09/12/2025 7:49 am
A I wrote before, I couldn't be happier with the Filamentalist solution. After trying several alternatives, it's the one that works for me. I have 8 rollers set up on a RepRack shelf, feeding with fairly long tubes to the MMU3. I use these magnetic twist lock connectors to swap to a PTFE feed line bypassing the MMU as needed. I use PTFE tubes with 2.5mm inner diameter and I've never experienced a friction issue.
One thing to note though. After my first assembly things seemed to work fine. But then I realized you really need to calibrate the tension properly, with both full and empty spools. Easy and quick but if done properly, fully loaded and almost empty spools rewind perfectly (at least for me).
Opublikowany : 09/12/2025 12:33 pm
1 ludzie polubili
Rainer
(@rainer-2)
I thought it had been a while. And sometimes the problems only arise after a while.
How long are your tubes? I also have my filament above the printer. Try to keep the length as short as possible.
Opublikowany : 09/12/2025 1:50 pm
About 30 inches.
Opublikowany : 09/12/2025 3:11 pm
strjan
(@strjan)
Did any one actually tried to print it in PETG?
Opublikowany : 07/01/2026 7:54 pm
Rainer
(@rainer-2)
I printed the rollers in PETG and the rest in ABS.
Everything works really well. I should have done this much earlier.
Once it's set up correctly, it doesn't matter whether the roll is full, almost empty, or a small one weighing 250 grams.
Opublikowany : 07/01/2026 8:21 pm
1 ludzie polubili
Steve
(@steve-11)
I think I printed the lot in PETG
Opublikowany : 07/01/2026 9:24 pm
Strona 2 / 2
