Parts and Modifiers Cannot be Painted or Seen on Bottom of Model
Mordeth
(@mordeth)
Oh Prusa Forums please come to my aid...
So I'm printing an Out of Order sign that I modeled in TinkerCAD and after making several changes and repainting the model maybe 7 times I'm now satisfied and want to add my logo (SVG) and "Made in NH, USA" (TEXT) to the bottom of the model flush with the build plate. Whether I use a part, or modifier I cannot get the model to recognize that there should be a color change, sometimes the pats won't show up at all. Other times if I scrub up through the first 5 bottom layers low-and-behold there's my text and logo in the center of the model. I've fiddled with the order of the text and logo and such to no avail. HELP! File is attached.
Napsal : 04/09/2024 10:46 pm
RE: Parts and Modifiers Cannot be Painted or Seen on Bottom of Model
There is no file attached.
project files MUST be ZIP Compressed and the zip file should be attached to the post.
Napsal : 05/09/2024 8:37 am
No file.
I suspect you may be creating the text at the centre of your part's Z range ... scroll down the right hand pane to 'Part Manipulation' and adjust the Z position, or in this case click the icon to the right and drop the text to the heatbed.
Napsal : 05/09/2024 8:55 am
