MK4 MMU3 Filament Change if a Spool is Finished Mid-Print
Miro J.
(@miro-j)
Is there a way to continue printing from the next filament slot if my filament runs out in slot 1 instead of replacing the spool? This is while using a non-MMU profile in PrusaSlicer for the MK4 with MMU3. Is there any option on the printer interface that I missed?
Posted : 24/07/2024 11:39 pm
Harlok67
(@harlok67)
RISPONDI: MK4 MMU3 Filament Change if a Spool is Finished Mid-Print
Hi,. I was about to ask the exact same question. Did you have a solution for SPOOL 1 end, continue SPOOL 2 ?
Posted : 18/08/2024 2:57 pm
Ermes
(@ermes)
RE: MK4 MMU3 Filament Change if a Spool is Finished Mid-Print
Hi. I have the same problem. I ran out of filament in the MMu3 on spool 1 to see what would happen.
The print stopped and I had to manually remove the filament from spool 1. Solutions?
Posted : 24/08/2024 11:42 am
Mike1D
(@mike1d)
I believe what you are looking for is called SpoolJoin that needs to be set on the printer.
https://help.prusa3d.com/article/spooljoin-mmu2s_134252
Posted : 10/09/2024 9:08 am
Miro J.
(@miro-j)
It would be handy to have it also as a button on the LCD screen when empyt spool is detected.
Posted : 10/09/2024 2:02 pm
