problem with Prusaslicer MMU
I just slice a new model, in fact my first multi'color' model, then I see that
will he print in fine air ?
here the .3mf https://drive.google.com/file/d/10K4ABQ7G4xHvNbTygti-8IBg3j9GMuFp/view?usp=sharing
RE: problem with Prusaslicer MMU
Yes its normal, its the ramming sequence so when it unloads the fillament its a flat round tip so it can go in and out the mmu easy. It will just be a string of fillament hangimg down like when you load fillament normally
thank you for answering
