					                		MMU3 for MK3S+ upgrade parts required for use with MK4/MK4S - Hardware, firmware and software help                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/mmu3-for-mk3s-upgrade-parts-required-for-use-with-mk4-mk4s/</link>
                <lastBuildDate>Thu, 21 May 2026 10:33:03 +0000</lastBuildDate>
                        <title>RE: MMU3 for MK3S+ upgrade parts required for use with MK4/MK4S</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/mmu3-for-mk3s-upgrade-parts-required-for-use-with-mk4-mk4s/#post-744825</link>
                        <pubDate>Tue, 08 Apr 2025 18:14:36 +0000</pubDate>
                        <description><![CDATA[You still need parts to modify the filament sensor on the Nextruder. Look in the assembly instructions for MMU3 in the section for mounting the MK4/MK4S sensor to see what parts are needed. ...]]></description>
                        <content:encoded><![CDATA[<p>You still need parts to modify the filament sensor on the Nextruder. Look in the assembly instructions for MMU3 in the section for mounting the MK4/MK4S sensor to see what parts are needed. You can print them yourself, they are listed in the MMU3 printable parts. Some screws still need to be changed and a new round magnet 3 x1mm is needed.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>miroslav.h4</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/mmu3-for-mk3s-upgrade-parts-required-for-use-with-mk4-mk4s/#post-744825</guid>
                        <title>MMU3 for MK3S+ upgrade parts required for use with MK4/MK4S</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/mmu3-for-mk3s-upgrade-parts-required-for-use-with-mk4-mk4s/#post-744228</link>
                        <pubDate>Fri, 04 Apr 2025 23:42:37 +0000</pubDate>
                        <description><![CDATA[MMU2S upgraded to MMU3 for MK3S+.  I am no now looking to upgrade it to be compatible ith MK4/MK4S.From what I can tell these are the only parts needed? Can anyone confirm?Main Plate set MMU...]]></description>
                        <content:encoded><![CDATA[<p>MMU2S upgraded to MMU3 for MK3S+.  I am no now looking to upgrade it to be compatible ith MK4/MK4S.</p><p>From what I can tell these are the only parts needed? Can anyone confirm?</p><p>Main Plate set MMU3 - https://www.prusa3d.com/product/main-plate-set-mmu3/<br />MMU3 Printer Cable for MK4 - https://www.prusa3d.com/product/mmu3-printer-cable-for-mk3-5-3-9-4/</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>morreale</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/mmu3-for-mk3s-upgrade-parts-required-for-use-with-mk4-mk4s/#post-744228</guid>
