MMU3 firmware update on MK4S
Netztroll
(@netztroll)
Hallo together,
I would just like to ask you whether a firmware upgrade of the MMU3 on the MK4S takes place during the firmware upgrade of the MK4S, or whether the MMU3 should also be updated manually?
This is not explained in the documentation. At least I have not found/read it.
Thank you in advance
Netztroll
This topic was modified 6 months temu by Netztroll
Opublikowany : 05/03/2025 8:58 am
to the best of my knowledge both the Mk4S and MMU3 latest Firmware downloads are found on the link below
https://help.prusa3d.com/downloads
details on how to update the MMU3 firmware are on the link below.
https://help.prusa3d.com/article/how-to-update-firmware-mmu3_701584
I Hope this helps you
Opublikowany : 05/03/2025 9:12 am
Antos
(@antos)
RE: MMU3 firmware update on MK4S
I'm wondering if you really need to update the firmware of the mmu3 everytime. For a long time it is still the same file: MMU3_FW3.0.3.+896.hex . Or do I miss something?
Opublikowany : 11/03/2025 11:06 pm
3Delight
(@3delight)
Moderator Moderator
I don't know what the official stance is but a quick scan of all the 896 hex files shows them to be identical on a binary level so the answer from me is no, you don't have to re-update the MMU3 if it is the same version number (896).
Opublikowany : 11/03/2025 11:50 pm
