MMU3 Firmware problem on MK3.5S...
3Delight
(@3delight)
Moderator Moderator
Hi everyone. I've just done the MMU3 update on my MK3.5S and it says that the MMU3 firmware needs updating. I downloaded the file from the main Prusa site and it links to the firmware zip for the MK3.9S and MK4S. I tried version 3.0.2 from GitHub but that keeps showing the version error! What can I do? I have the 6.2.0 Mk3.5S printer firmware installed.
Posted : 12/02/2025 7:18 pm
RE: MMU3 Firmware problem on MK3.5S...
Have you tried  MMU3 firmware 3.0.3
https://help.prusa3d.com/downloads
Oddly the mk3.5S MMU3 link takes you to the Zipfile for Mk4 and Mk3.9. but there is a hex file for MMU3 V3.0.3 in the unzipped folder
Posted : 12/02/2025 10:45 pm
3Delight
(@3delight)
Moderator Moderator
Thanks Joan.  I've finally fixed by changing the filename in the downloads URL, so the correct file is there and contains the correct (& compatible) firmware for both the printer and the MMU3.
Now I've just go to find out why the filament stops half way to the extruder?!  Oh joy! 😆
UPDATE
It seems that it was a problem with the filament.  Unloaded it, cut a section off and shaped the tip better into a point and it just worked perfectly.
Posted : 13/02/2025 12:54 am
