MK3S (Not +) compatible with MMU3?
Hi everyone! My bad... I didn't realize MMU3 is only compatible with the MK3S+ version (I have the MK3S). So, I figured that out after I received the MMU3 upgrade package. But well... I managed to install it anyway, and it works, not the best way, but it works. I've been researching the differences between both versions. There are three major ones: the Super Pinda (gives better first layers), a new IR sensor, and a different PTFE tube (some minor changes in dimension). I could buy the MK3S+ upgrade, but for me (I live in Argentina), it's really expensive.
Is the upgrade really necessary? Has anyone else tried installing it anyway?
Thank you very much!
RE: MK3S (Not +) compatible with MMU3?
You don't need to buy the MK3+ upgrade kit. I setup my MK3S with the MMU3 without doing the + upgrade and it worked fine.
Upgrading the extender to the MK3S+ parts allows you to use the nice sensor adjustment parts that come with the MMU3.
Great! Thanks!
Yeah I have an MK3S and I just printed out the extruder parts for the MK3S+ and the MMU3 worked like a charm.
Yes works well
