Is it possible to bypass the MMU3 for, say, flexi-filaments?
TrackZero
(@trackzero)
I'm sure this is probably answered somewhere, but I haven't found anyone talking about it....One of the big problems I had with the MMU2 (and there were many), when I wanted to do a TPU print, I had to do a bunch of janky stuff to trick the filament sensor and then feed the filament physically outside of the MMU2.  I finally just unplugged the power & data connections & went to single-filament as my default.
Now I have the MMU3 upgrade kit, but before I install it...Am I able to physically bypass it via configuration/software for single-filament prints, or is it the same as the MMU2....once installed, it's the only way to feed filament?
Best Answer by JoanTabb:
the Mk3 and mk4 LCD Menu's allow you to turn the MMU3 off   (this may be a function of the daughterboard on the MMU, so may not be an option, on MMU2 using MMU3 Firmware... )
so yes, you can turn the MMU3 off, and use TPU Directly to the Printer, BUT... you will probably have to manually load the filament because TPU is unlikely to be rigid enough to push through the bondtech gears
Veröffentlicht : 05/11/2023 7:33 pm
RE: Is it possible to bypass the MMU3 for, say, flexi-filaments?
Veröffentlicht : 05/11/2023 8:18 pm
3 weiteren Personen gefällt das
K7ZPJ
(@k7zpj)
Here is how I do it:
Disable the MMU3 and filament sensor from the LCD menu.
You can then feed the flex filament down the filament path.  On really soft filament, remove the idler,  get the filament down to the bondtech gears and then put the idler back on and tension it.
This works for the MMU2 too.  You disconnect the power to disable it.
Veröffentlicht : 05/11/2023 8:21 pm
TrackZero
(@trackzero)
Awesome, thanks, then I think I will actually go ahead and finish this build. 🙂
Veröffentlicht : 05/11/2023 8:43 pm
I like my MMU3...
Joan
Veröffentlicht : 06/11/2023 5:33 pm
4 weiteren Personen gefällt das
Her MannF
(@her-mannf)
@Joan thanks for the tip. Now it is possible for me to print with the new filament sensor on the Nextruder TPU with 80 Shore without much effort. Maybe a mod will come along that doesn't require any tricks.
Diese r Beitrag wurde geändert Vor 1 year von Her MannF
Veröffentlicht : 28/04/2024 9:42 am
