					                		Flashing MMU3 firmware from Ubuntu 22.04.4 failures - Hardware, firmware and software help                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/flashing-mmu3-firmware-from-ubuntu-22-04-4-failures/</link>
                <lastBuildDate>Fri, 05 Jun 2026 23:13:19 +0000</lastBuildDate>
                        <title>RE: Flashing MMU3 firmware from Ubuntu 22.04.4 failures</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/flashing-mmu3-firmware-from-ubuntu-22-04-4-failures/#post-727256</link>
                        <pubDate>Sun, 17 Nov 2024 22:46:17 +0000</pubDate>
                        <description><![CDATA[I had the same issue and I hate to break it to you how easy the fix was. I&#039;d just the firmware on my MK3S+ (main machine, not the MMU) and that disabled my MMU. Once I went to Settings -&gt;...]]></description>
                        <content:encoded><![CDATA[<p>I had the same issue and I hate to break it to you how easy the fix was. I'd just the firmware on my MK3S+ (main machine, not the MMU) and that disabled my MMU. Once I went to Settings -&gt; MMU  on my printer's LDC screen I could find and connect to the MMU with my computer.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>annswims</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/flashing-mmu3-firmware-from-ubuntu-22-04-4-failures/#post-727256</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/flashing-mmu3-firmware-from-ubuntu-22-04-4-failures/#post-723046</link>
                        <pubDate>Fri, 27 Sep 2024 15:45:50 +0000</pubDate>
                        <description><![CDATA[I experienced this issue as well when I first installed the MMU3 on my MK4.  Resolved then by using a Windows machine.Tried again today to upgrade the firmware to match the new MK4S, issue i...]]></description>
                        <content:encoded><![CDATA[<p>I experienced this issue as well when I first installed the MMU3 on my MK4.  Resolved then by using a Windows machine.<br /><br />Tried again today to upgrade the firmware to match the new MK4S, issue is still there.<br /><br />Not sure if this is something Prusa can do anything about, when I checked dmesg output this is what I see when I connect my Pop!_OS machine (Ubunut derivative). Looks to be an incompatibilty, but not sure if it is the USB driver or in the MMU3 USB interface.</p><pre contenteditable="false"> usb 2-1.5.1.1: new full-speed USB device number 33 using ehci-pci
 usb 2-1.5.1.1: New USB device found, idVendor=2c99, idProduct=0004, bcdDevice= 0.01
 usb 2-1.5.1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
 usb 2-1.5.1.1: Product: Original Prusa MMU unit 🐑
 usb 2-1.5.1.1: Manufacturer: prusa3d.com
 BPF: 	 type_id=3987 bits_offset=32
 BPF:  
 BPF: Invalid name
 BPF: 
 failed to validate module  BTF: -22
</pre>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>JediRick</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/flashing-mmu3-firmware-from-ubuntu-22-04-4-failures/#post-723046</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/flashing-mmu3-firmware-from-ubuntu-22-04-4-failures/#post-716226</link>
                        <pubDate>Fri, 12 Jul 2024 21:00:09 +0000</pubDate>
                        <description><![CDATA[I have the same on MAC OS Sonoma 14.5 No way to reset the MMU3 nor to flash it.Used 5 different cables that all work for data transfer on other apps.]]></description>
                        <content:encoded><![CDATA[<p>I have the same on MAC OS Sonoma 14.5 </p><p>No way to reset the MMU3 nor to flash it.</p><p>Used 5 different cables that all work for data transfer on other apps</p><p>.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Ron</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/flashing-mmu3-firmware-from-ubuntu-22-04-4-failures/#post-716226</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/flashing-mmu3-firmware-from-ubuntu-22-04-4-failures/#post-704683</link>
                        <pubDate>Wed, 20 Mar 2024 14:18:34 +0000</pubDate>
                        <description><![CDATA[Hello. 
Today I had the same problem when trying to update to the latest firmware. And in the device tab my MMU3 doesn&#039;t detect me. I&#039;ve changed three wires but I still can&#039;t detect the MMU...]]></description>
                        <content:encoded><![CDATA[<p>Hello. </p>
<p>Today I had the same problem when trying to update to the latest firmware. And in the device tab my MMU3 doesn't detect me. I've changed three wires but I still can't detect the MMU unit.</p>
<p>What else can you be??</p>
<p>Gracias</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Robvene</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/flashing-mmu3-firmware-from-ubuntu-22-04-4-failures/#post-704683</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/flashing-mmu3-firmware-from-ubuntu-22-04-4-failures/#post-703670</link>
                        <pubDate>Tue, 12 Mar 2024 16:33:12 +0000</pubDate>
                        <description><![CDATA[Only thing I have not changed was the USB cable.Re-tested that this morning and see that it is broken.  I assumed it was ok since it was in use on another development board and worked fine t...]]></description>
                        <content:encoded><![CDATA[<p>Only thing I have not changed was the USB cable.</p><p>Re-tested that this morning and see that it is broken.  I assumed it was ok since it was in use on another development board and worked fine there.  Maybe damaged it removing it from the rack?</p><p>Bought a fresh new one this morning and the MMU shows up and can be flashed just fine.</p><p>When in doubt, check your cables!</p><p> </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>DrTomFlint</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/flashing-mmu3-firmware-from-ubuntu-22-04-4-failures/#post-703670</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/flashing-mmu3-firmware-from-ubuntu-22-04-4-failures/#post-703620</link>
                        <pubDate>Tue, 12 Mar 2024 08:14:51 +0000</pubDate>
                        <description><![CDATA[As soon as you click tbe rest button press flash, you have to click flash w8thin 5 seconds of the mmu turning on or resetting]]></description>
                        <content:encoded><![CDATA[<p>As soon as you click tbe rest button press flash, you have to click flash w8thin 5 seconds of the mmu turning on or resetting</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Hello</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/flashing-mmu3-firmware-from-ubuntu-22-04-4-failures/#post-703620</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/flashing-mmu3-firmware-from-ubuntu-22-04-4-failures/#post-703614</link>
                        <pubDate>Tue, 12 Mar 2024 03:38:50 +0000</pubDate>
                        <description><![CDATA[Trashed one of my perfectly good Linux laptops to install windows 8.1.First was missing api-ms-win-crt-l1-1-0.dll and had to do a bunch of updates, took more than 2 hours.Eventually got a wo...]]></description>
                        <content:encoded><![CDATA[<p>Trashed one of my perfectly good Linux laptops to install windows 8.1.</p><p>First was missing api-ms-win-crt-l1-1-0.dll and had to do a bunch of updates, took more than 2 hours.</p><p>Eventually got a working Windows 8.1 installation that could run the Prusa Slicer V 2.7.1.</p><p>Try to do the firmware update on the MMU and got the same exact failure.</p><p>I used to Love prusa.  Starting to revise that opinion.  Three entire days wasted on this effort.  I am not a happy camper.</p><p> </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/flashing-mmu3-firmware-from-ubuntu-22-04-4-failures/#post-703614</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/flashing-mmu3-firmware-from-ubuntu-22-04-4-failures/#post-703602</link>
                        <pubDate>Mon, 11 Mar 2024 23:39:51 +0000</pubDate>
                        <description><![CDATA[Further tests: Built a Debian 12 laptop and got the same exact results.]]></description>
                        <content:encoded><![CDATA[<p>Further tests: Built a Debian 12 laptop and got the same exact results.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/flashing-mmu3-firmware-from-ubuntu-22-04-4-failures/#post-703602</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/flashing-mmu3-firmware-from-ubuntu-22-04-4-failures/#post-703561</link>
                        <pubDate>Mon, 11 Mar 2024 18:33:15 +0000</pubDate>
                        <description><![CDATA[That does seem to be the common fix.  I don&#039;t have a Windows license.  So unless I convince a friend to stop by or lend me a machine...]]></description>
                        <content:encoded><![CDATA[<p>That does seem to be the common fix.  I don't have a Windows license.  So unless I convince a friend to stop by or lend me a machine...</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/flashing-mmu3-firmware-from-ubuntu-22-04-4-failures/#post-703561</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/flashing-mmu3-firmware-from-ubuntu-22-04-4-failures/#post-703560</link>
                        <pubDate>Mon, 11 Mar 2024 18:27:14 +0000</pubDate>
                        <description><![CDATA[Do you have access to a windows device, to try flashing with?regards Joan]]></description>
                        <content:encoded><![CDATA[<p>Do you have access to a windows device, to try flashing with?<br /><br />regards Joan<br /><br /></p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>JoanTabb</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/flashing-mmu3-firmware-from-ubuntu-22-04-4-failures/#post-703560</guid>
