Firmware change request
Hoof Hearted
(@hoof-hearted)
This is a MK4 + MMU3 setup. If I send a model from Prusaslicer and I have accidentally configured it to use an empty channel on the MMU, this is recognised and the screen gives me a 'Retry' button for when I have put some filament in that channel. But if I want to cancel the operation and re-send the gcode for the correct channel, I cannot get out of the 'Retry' screen. I have to reset the printer.
Can we have a 'Cancel' option also in that screen please?
Postato : 06/07/2024 10:42 am
1 persone hanno apprezzato
aliennatn
(@aliennatn)
Utenti
RE: Firmware change request
There should be a "cancel" or "abort" button whenever there is a "retry" button.  There have been several situations where retry is not an option, as I have a hardware or filament issue, and I have to reset the printer.
Postato : 27/10/2024 3:12 am
Could you please look on Github, if there is an existing request, add your comments to it,  otherwise open anew request.
Github is where the developers operate.
Postato : 27/10/2024 8:29 am
