Filament Error on CoreOne Menu
ponti33602
(@ponti33602)
I have been adding an MMU3 to my CoreOne and utilizing a CoreBoxx.  I have removed the filament sensor from the Nextruder   as it will be sensed from the MMU3.  However, when I turn on the CoreOne it has an error stating "Unload Manually Filament Detected"  It will not let me proceed from this screen.  I need to somehow bypass this error and get to the Home Screen so I can finish the MMU3.  I have already told the CoreOne that I have an MMU3 and it told me that the filament sensor will now be located within the MMU3.
Can someone help me on how to bypass this error so I can get back to the Home Screen?
Posted : 19/11/2025 7:41 pm
RE: Filament Error on CoreOne Menu
mmu3 0n other printers needs Finda, on MMU3 Selector, and Filament sensor on extruder
i expect core1 is the same
https://help.prusa3d.com/guide/9d-core-one-nextruder-mod_111779#126373
see around section 19
Posted : 19/11/2025 10:31 pm
mnentwig
(@mnentwig)
Posted by: @ponti33602
I sense a disconnect here because the MMU instructions I got with my MMU kit reassembled the Nextruder filament sensor with improved parts. And I see how this is integrated, it plays an important role with multiple error conditions to bail out if the filament has a mind of its own (which does seem to happen frequently during the "pipe-cleaning" phase, not in regular operation).
I'd suggest to double-check the assembly manual.
Posted : 19/11/2025 10:44 pm
