					                		Filament always gets stuck in Nextruder on retraction—but only filament 5 - Hardware, firmware and software help                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/filament-always-gets-stuck-in-nextruder-on-retraction-but-only-filament-5/</link>
                <lastBuildDate>Fri, 15 May 2026 08:41:05 +0000</lastBuildDate>
                        <title>RE: Filament always gets stuck in Nextruder on retraction—but only filament 5</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/filament-always-gets-stuck-in-nextruder-on-retraction-but-only-filament-5/#post-782955</link>
                        <pubDate>Sat, 21 Feb 2026 02:29:28 +0000</pubDate>
                        <description><![CDATA[I use a loading fork/guide in the buffer and have on occasion forgotten to remove it after loading. Could it be something this simple?If not, I’d suspect a restriction between the MMU and th...]]></description>
                        <content:encoded><![CDATA[<p>I use a loading fork/guide in the buffer and have on occasion forgotten to remove it after loading. Could it be something this simple?</p><p>If not, I’d suspect a restriction between the MMU and the buffer on #5. Also check the set screw on the drive spur in the MMU #5.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Tom De Winter</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/filament-always-gets-stuck-in-nextruder-on-retraction-but-only-filament-5/#post-782955</guid>
                        <title>Filament always gets stuck in Nextruder on retraction—but only filament 5</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/filament-always-gets-stuck-in-nextruder-on-retraction-but-only-filament-5/#post-782948</link>
                        <pubDate>Fri, 20 Feb 2026 22:41:32 +0000</pubDate>
                        <description><![CDATA[I&#039;ve got an MMU3 with a MK4S. Filament 5 keeps getting stuck when being extracted from the Nextruder. I have no clue why this happens. I just cleaned the MMU3 itself so there is no debris in...]]></description>
                        <content:encoded><![CDATA[<p>I've got an MMU3 with a MK4S. Filament 5 keeps getting stuck when being extracted from the Nextruder. I have no clue why this happens. I just cleaned the MMU3 itself so there is no debris in there. </p><p>I just finished the simple 5 color test ring and everything went smoothly. I then tried something harder like the 5 color benchy. Every time color 5 unloads, it gets stuck in the Nextruder—but only color 5. All the filaments are the same material, age, and brand. (Granted it's a cheap brand.) </p><p><strong>Why would only color 5 get stuck?</strong></p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>jlconlin</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/filament-always-gets-stuck-in-nextruder-on-retraction-but-only-filament-5/#post-782948</guid>
