Error: PRUSATOOLCHANGER
Bryann25
(@bryann25)
This just started this morning.  It's an MK4 with an MMU3 and it was running fine last week using the MMU3.  Today, I can print single filament programs fine but I get this error when I try to use the MMU3.  Any advice would be appreciated.
Posted : 29/07/2024 5:18 pm
chandler
(@chandler-2)
RE: Error: PRUSATOOLCHANGER
Hi Bryan,
have you found a solution for your posted problem? I have the same behaviour  with my MK4/MMU3 and cannot find a solution for it. Pleas be so kind and give me a hint when possible.
ThanX
Chris
Posted : 31/10/2024 3:25 pm
Mike B
(@mike-b-3)
This looks like an error that should only appear on an XL or other multi-extruder printer.  Maybe check the printer type in PS, or that you don't have multiple extruders defined?  I have yet to assemble my MMU3 so I'm guessing...
Posted : 31/10/2024 7:32 pm
chandler
(@chandler-2)
Dear Mike,
it appears on my MK4/MMU3. I send files from PrusaSlicer with the original MK4 MMU3 Printer Profile.
Something what I found out is, that it may have something to do with any printer setings in the slicer. I set it up with a soluble support (support material/Options for support material/Top contact Z distance: 0(soluble)). With this I do not get this error for now. I hope it stays working 🤨
Posted : 31/10/2024 8:58 pm
chandler
(@chandler-2)
Afraid to say, but I again received this error and I do not know what causes it. Obviously it is any setting in printer settings.
Posted : 03/11/2024 7:33 pm
