					                		Core One MMU3 installation issue – filament detected unexpectedly - Hardware, firmware and software help                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/core-one-mmu3-installation-issue-filament-detected-unexpectedly/</link>
                <lastBuildDate>Tue, 09 Jun 2026 15:34:52 +0000</lastBuildDate>
                        <title>RE: Core One MMU3 installation issue – filament detected unexpectedly</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/core-one-mmu3-installation-issue-filament-detected-unexpectedly/#post-786010</link>
                        <pubDate>Mon, 16 Mar 2026 16:08:50 +0000</pubDate>
                        <description><![CDATA[Check again or carefully recalibrate both sensors. If you look at the bottom line of the display, both sensors report that filament is present! The penultimate symbol belongs to the sensor o...]]></description>
                        <content:encoded><![CDATA[<p>Check again or carefully recalibrate both sensors. If you look at the bottom line of the display, both sensors report that filament is present! The penultimate symbol belongs to the sensor on the Nextruder, the one on the far right belongs to FINDA! And if the MMU does not move at startup, it is caused by the FINDA message, there must be no filament in the selector at startup!</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>miroslav.h4</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/core-one-mmu3-installation-issue-filament-detected-unexpectedly/#post-786010</guid>
                        <title>Core One MMU3 installation issue – filament detected unexpectedly</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/core-one-mmu3-installation-issue-filament-detected-unexpectedly/#post-785941</link>
                        <pubDate>Mon, 16 Mar 2026 04:13:46 +0000</pubDate>
                        <description><![CDATA[Hi everyone,I’m trying to install and run an MMU3 on my Prusa Core One, but I keep getting the following error on the screen:“Unload Manually – Filament detected unexpectedly. Ensure no fila...]]></description>
                        <content:encoded><![CDATA[<p><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2026/03/8aa26e59-mu3_error.jpg"><img class="alignnone size-medium wp-image-185201" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2026/03/8aa26e59-mu3_error-600x301.jpg" alt="" width="600" height="301" /></a></p><p data-start="190" data-end="202">Hi everyone,</p><p data-start="204" data-end="321">I’m trying to install and run an <strong data-start="237" data-end="266">MMU3 on my Prusa Core One</strong>, but I keep getting the following error on the screen:</p><p data-start="323" data-end="438"><strong data-start="323" data-end="438">“Unload Manually – Filament detected unexpectedly. Ensure no filament is loaded. Check the sensors and wiring.”</strong></p><p data-start="440" data-end="535">At the same time, the <strong data-start="462" data-end="496">MMU3 unit does not move at all</strong> when the printer starts the procedure.</p><p data-start="537" data-end="562">Things I already checked:</p><p data-start="566" data-end="614">There is <strong data-start="575" data-end="597">no filament loaded</strong> in the extruder.</p><p data-start="617" data-end="674">I verified the <strong data-start="632" data-end="652">sensor alignment,</strong> and it looks correct.</p><p data-start="677" data-end="760">I checked the <strong data-start="691" data-end="723">FINDA / filament sensor area</strong> to make sure nothing is blocking it.</p><p data-start="763" data-end="829"><strong data-start="763" data-end="796">Sensor position seems correct</strong> and not triggering mechanically.</p><p data-start="832" data-end="883">Wiring for the <strong data-start="847" data-end="882">MMU3 appears properly connected</strong>.</p><p data-start="886" data-end="936">I tried <strong data-start="894" data-end="903">Retry</strong> and also restarting the printer.</p><p data-start="938" data-end="951">Printer info:</p><p data-start="954" data-end="972"><strong data-start="954" data-end="972">Prusa Core One</strong></p><p data-start="975" data-end="993"><strong data-start="975" data-end="993">MMU3 installed</strong></p><p data-start="996" data-end="1029"> </p><p data-start="1031" data-end="1136">Despite this, the printer still thinks filament is present, and the <strong data-start="1099" data-end="1135">MMU3 does not move or initialize</strong>.</p><p data-start="1138" data-end="1320">Has anyone experienced this with the <strong data-start="1175" data-end="1200">Core One + MMU3 setup</strong>? Is there something specific about <strong data-start="1238" data-end="1300">sensor calibration, FINDA position, or MMU3 initialization</strong> I might be missing?</p><p data-start="1322" data-end="1367">Any suggestions would be greatly appreciated.</p><p data-start="1369" data-end="1376">Thanks!</p><p> </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Prusa_Tuncer</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/core-one-mmu3-installation-issue-filament-detected-unexpectedly/#post-785941</guid>
