					                		cant flash mmu 3.0.4 firmware to MMU - Hardware, firmware and software help                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/cant-flash-mmu-3-0-4-firmware-to-mmu/</link>
                <lastBuildDate>Tue, 16 Jun 2026 02:50:52 +0000</lastBuildDate>
                        <title>RE: cant flash mmu 3.0.4 firmware to MMU</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/cant-flash-mmu-3-0-4-firmware-to-mmu/#post-788033</link>
                        <pubDate>Fri, 03 Apr 2026 07:48:25 +0000</pubDate>
                        <description><![CDATA[I talked with the support. First they couldn&#039;t help because they did not understand the error-log. They forwarded to an MMU expert and this &quot;expert&quot; replied that I need to replace the MMU. B...]]></description>
                        <content:encoded><![CDATA[<p>I talked with the support. First they couldn't help because they did not understand the error-log. They forwarded to an MMU expert and this "expert" replied that I need to replace the MMU. But the MMU is working fine without any problem. And the update process did find the boot loader on the MMU. I deleted all Prusa Apps and driver and reinstalled it - no success.Finally I used the computer of my wife, also a Win11 system. And surprise: the update process did work.Conclusion:- the prusa support has no clue</p><p>- the parameter of the communication on the MMU are not set for a reliable flash process. Prusa needs to fix this problem.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Volker</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/cant-flash-mmu-3-0-4-firmware-to-mmu/#post-788033</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/cant-flash-mmu-3-0-4-firmware-to-mmu/#post-787788</link>
                        <pubDate>Mon, 30 Mar 2026 18:58:45 +0000</pubDate>
                        <description><![CDATA[I have the same problem. I checked with different cables - no difference. Once the flash process is started the MMU is reseting - therefore there is some data communication. But then nothing...]]></description>
                        <content:encoded><![CDATA[<p>I have the same problem. I checked with different cables - no difference. Once the flash process is started the MMU is reseting - therefore there is some data communication. But then nothing works. Please finde my error log.</p>
<div id="wpfa-185589" class="wpforo-attached-file"><a class="wpforo-default-attachment" href="//storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/wpforo/default_attachments/1774897126-68280797-prusa-mmu3-error-logtxt.txt" target="_blank" title="68280797-prusa-mmu3-error-logtxt.txt"><i class="fas fa-paperclip"></i>&nbsp;68280797-prusa-mmu3-error-logtxt.txt</a></div>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/cant-flash-mmu-3-0-4-firmware-to-mmu/#post-787788</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/cant-flash-mmu-3-0-4-firmware-to-mmu/#post-787591</link>
                        <pubDate>Fri, 27 Mar 2026 18:38:33 +0000</pubDate>
                        <description><![CDATA[Yep that&#039;s how I got it done also once I found out the USB cable I was using didn&#039;t have data lines connect. They need to find some why of marking those.  One of the best purchases I&#039;ve made...]]></description>
                        <content:encoded><![CDATA[<p>Yep that's how I got it done also once I found out the USB cable I was using didn't have data lines connect. They need to find some why of marking those.  One of the best purchases I've made in the past year was a cable tester. </p><p>Thanks for the reply.</p><p>Tanks </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Lynn</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/cant-flash-mmu-3-0-4-firmware-to-mmu/#post-787591</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/cant-flash-mmu-3-0-4-firmware-to-mmu/#post-787586</link>
                        <pubDate>Fri, 27 Mar 2026 17:02:18 +0000</pubDate>
                        <description><![CDATA[I have same issue as reported at top of thread.  Trying to update the firmware on my MMU3 attached to my CoreOne+.  I am using MacBook Pro with Tahoe 26.2I am using the USB cable supplied wi...]]></description>
                        <content:encoded><![CDATA[<p>I have same issue as reported at top of thread.  <br /><br />Trying to update the firmware on my MMU3 attached to my CoreOne+.  I am using MacBook Pro with Tahoe 26.2I am using the USB cable supplied with the MMU3 and the Apple dongle to connect it to my MacBook Pro (which has only USB-C ports).</p><p>Here is the output from the debug log:</p><p>avrdude-slic3r -v -p atmega2560 -c wiring -P /dev/cu.usbmodem114201 -b 115200 -D -U</p><p>flash:w:0:/Users/bbosveld/Downloads/prusa3d_fw_MMU3_3_0_4_CORE_One_CORE_One+_6_5_3(2).zip:i</p><p>avrdude-slic3r: Version 6.3-20160220-prusa3d, compiled on Nov  6 2025 at 10:29:53<br />                Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/<br />                Copyright (c) 2007-2014 Joerg Wunsch<br /><br />                Using Port                    : /dev/cu.usbmodem114201<br />                Using Programmer              : wiring<br />                Overriding Baud Rate          : 115200<br />avrdude-slic3r: stk500v2_recv(): timeout<br />avrdude-slic3r: stk500v2_getsync(): timeout communicating with programmer<br />avrdude-slic3r: Could not open port: /dev/cu.usbmodem114201avrdude-slic3r done.  </p><p>Thank you.</p><p> </p><p>There are three choices for serial port to choose from.  None of them complete successfully.<br /><br />Any suggestions would be greatly appreciated.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>bbosveld</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/cant-flash-mmu-3-0-4-firmware-to-mmu/#post-787586</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/cant-flash-mmu-3-0-4-firmware-to-mmu/#post-787526</link>
                        <pubDate>Fri, 27 Mar 2026 04:59:59 +0000</pubDate>
                        <description><![CDATA[I did it by using PrusaSlicer on a computer connected via USB to the MMU3 directly.]]></description>
                        <content:encoded><![CDATA[<p>I did it by using PrusaSlicer on a computer connected via USB to the MMU3 directly.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Mike B</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/cant-flash-mmu-3-0-4-firmware-to-mmu/#post-787526</guid>
                        <title>cant flash mmu 3.0.4 firmware to MMU</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/cant-flash-mmu-3-0-4-firmware-to-mmu/#post-787519</link>
                        <pubDate>Fri, 27 Mar 2026 01:50:47 +0000</pubDate>
                        <description><![CDATA[I flashed the core one firmware to 6.5.3 and tried to flash the MMU to 3.0.4.  If fails the update. I&#039;ve tried every method to push the firmware that I could find and have had no luck.
Is t...]]></description>
                        <content:encoded><![CDATA[<p>I flashed the core one firmware to 6.5.3 and tried to flash the MMU to 3.0.4.  If fails the update. I've tried every method to push the firmware that I could find and have had no luck.</p>
<p>Is there a preferred method anyone can recommend?  Do I have to down flash the core one to make it work?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-hardware-firmware-and-software-help/cant-flash-mmu-3-0-4-firmware-to-mmu/#post-787519</guid>
