cant flash mmu 3.0.4 firmware to MMU
Lynn
 Lynn
(@lynn)
I flashed the core one firmware to 6.5.3 and tried to flash the MMU to 3.0.4.  If fails the update. I've tried every method to push the firmware that I could find and have had no luck.
Is there a preferred method anyone can recommend?  Do I have to down flash the core one to make it work?
Dieses Thema wurde geändert Vor 3 months von Lynn
Veröffentlicht : 27/03/2026 1:50 am
Mike B
(@mike-b-3)
RE: cant flash mmu 3.0.4 firmware to MMU
I did it by using PrusaSlicer on a computer connected via USB to the MMU3 directly.
Veröffentlicht : 27/03/2026 4:59 am
bbosveld
(@bbosveld)
Mitglied
I have same issue as reported at top of thread.
Trying to update the firmware on my MMU3 attached to my CoreOne+.  I am using MacBook Pro with Tahoe 26.2I am using the USB cable supplied with the MMU3 and the Apple dongle to connect it to my MacBook Pro (which has only USB-C ports).
Here is the output from the debug log:
avrdude-slic3r -v -p atmega2560 -c wiring -P /dev/cu.usbmodem114201 -b 115200 -D -U
flash:w:0:/Users/bbosveld/Downloads/prusa3d_fw_MMU3_3_0_4_CORE_One_CORE_One+_6_5_3(2).zip:i
avrdude-slic3r: Version 6.3-20160220-prusa3d, compiled on Nov  6 2025 at 10:29:53
                Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
                Copyright (c) 2007-2014 Joerg Wunsch
                Using Port                    : /dev/cu.usbmodem114201
                Using Programmer              : wiring
                Overriding Baud Rate          : 115200
avrdude-slic3r: stk500v2_recv(): timeout
avrdude-slic3r: stk500v2_getsync(): timeout communicating with programmer
avrdude-slic3r: Could not open port: /dev/cu.usbmodem114201avrdude-slic3r done.
Thank you.
There are three choices for serial port to choose from.  None of them complete successfully.
Any suggestions would be greatly appreciated.
Veröffentlicht : 27/03/2026 5:02 pm
Lynn
 Lynn
(@lynn)
Yep that's how I got it done also once I found out the USB cable I was using didn't have data lines connect. They need to find some why of marking those.  One of the best purchases I've made in the past year was a cable tester.
Thanks for the reply.
Tanks
Veröffentlicht : 27/03/2026 6:38 pm
Volker
(@volker)
I have the same problem. I checked with different cables - no difference. Once the flash process is started the MMU is reseting - therefore there is some data communication. But then nothing works. Please finde my error log.
Veröffentlicht : 30/03/2026 6:58 pm
Volker
(@volker)
I talked with the support. First they couldn't help because they did not understand the error-log. They forwarded to an MMU expert and this "expert" replied that I need to replace the MMU. But the MMU is working fine without any problem. And the update process did find the boot loader on the MMU. I deleted all Prusa Apps and driver and reinstalled it - no success.Finally I used the computer of my wife, also a Win11 system. And surprise: the update process did work.Conclusion:- the prusa support has no clue
- the parameter of the communication on the MMU are not set for a reliable flash process. Prusa needs to fix this problem.
Veröffentlicht : 03/04/2026 7:48 am
