					                		Prusa Slicer - wipe tower issues - General discussion, announcements and releases                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-general-discussion-announcements-and-releases/prusa-slicer-wipe-tower-issues/</link>
                <lastBuildDate>Sun, 08 Mar 2026 00:08:25 +0000</lastBuildDate>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-general-discussion-announcements-and-releases/prusa-slicer-wipe-tower-issues/#post-784361</link>
                        <pubDate>Wed, 04 Mar 2026 11:17:24 +0000</pubDate>
                        <description><![CDATA[Yes, but take care.  You need enough room for the purge...  You also have the option of wipe into object - effectively a wipe tower shaped like something useful; OK for colour changes but no...]]></description>
                        <content:encoded><![CDATA[<p>Yes, but take care.  You need enough room for the purge...  You also have the option of wipe into object - effectively a wipe tower shaped like something useful; OK for colour changes but not material - and wipe to infill,  ditto.  Both the latter take some planning as the object must be taller that the last change and big enough at all layers to accept the wipes.</p><p>Select object, right click &gt; Wipe options.</p><p>Like all defaults the wipe tower it is rarely optimum, often, (especially if you expect to reprint several) it can be better to design your own; create a suitable object, use modifiers to reduce filament usage then make it the wipe-to object.</p><p>I have an almost full-bed print on my XL for which I have edited the wipe tower to 6mm wide along one edge - but all the tool changes are within the first 2mm so the 'tower' only gets about 10 layers tall and stability isn't an issue.</p><p>Cheerio,</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>Diem</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-general-discussion-announcements-and-releases/prusa-slicer-wipe-tower-issues/#post-784361</guid>
                        <title>RE: Prusa Slicer - wipe tower issues</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-general-discussion-announcements-and-releases/prusa-slicer-wipe-tower-issues/#post-784329</link>
                        <pubDate>Wed, 04 Mar 2026 01:21:02 +0000</pubDate>
                        <description><![CDATA[I am sure this has been asked many times before...but, can I make the wipe tower footprint smaller?  My first MMU3 prints on my C1.]]></description>
                        <content:encoded><![CDATA[<p>I am sure this has been asked many times before...but, can I make the wipe tower footprint smaller?  My first MMU3 prints on my C1.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>Mac-N4MCC</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-general-discussion-announcements-and-releases/prusa-slicer-wipe-tower-issues/#post-784329</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-general-discussion-announcements-and-releases/prusa-slicer-wipe-tower-issues/#post-780934</link>
                        <pubDate>Thu, 05 Feb 2026 19:52:18 +0000</pubDate>
                        <description><![CDATA[Hey, I’ve found a partial workaround for your first issue.I also find it frustrating that when I hit the Arrange button, the purge block moves as well—especially when I’m only printing with ...]]></description>
                        <content:encoded><![CDATA[<p data-start="118" data-end="176">Hey, I’ve found a partial workaround for your first issue.</p><p data-start="178" data-end="549">I also find it frustrating that when I hit the Arrange button, the purge block moves as well—especially when I’m only printing with a single filament. What I do instead is enable <strong data-start="357" data-end="382">Background Processing </strong>- <strong>under the Configuration Tab</strong>. That way, as soon as an object on the plate is set to use only one colour, the purge block disappears, which then lets me arrange the parts without it moving around.</p><p data-start="551" data-end="794">If you want to print everything in different filaments, place all the parts on the plate first, then select <strong data-start="659" data-end="675">Auto Arrange</strong>, and only after that choose the filament for each print. This will place the purge block back in its default position.</p><p data-start="796" data-end="865">Hopefully this helps you—and anyone else running into the same issue.</p><p data-start="796" data-end="865"> </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>Josh</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-general-discussion-announcements-and-releases/prusa-slicer-wipe-tower-issues/#post-780934</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-general-discussion-announcements-and-releases/prusa-slicer-wipe-tower-issues/#post-728489</link>
                        <pubDate>Fri, 29 Nov 2024 20:16:00 +0000</pubDate>
                        <description><![CDATA[i would love to know how to print the wipe tower base first.]]></description>
                        <content:encoded><![CDATA[<p>i would love to know how to print the wipe tower base first.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>whitestormy</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-general-discussion-announcements-and-releases/prusa-slicer-wipe-tower-issues/#post-728489</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-general-discussion-announcements-and-releases/prusa-slicer-wipe-tower-issues/#post-725364</link>
                        <pubDate>Fri, 25 Oct 2024 09:18:21 +0000</pubDate>
                        <description><![CDATA[Posted by: @mysticgringo Hi...I have a few annoying issues that aren&#039;t show stoppers, but adds steps to my workflow, and frankly annoy me.1. I want the wipe tower to stay put when I hit the ...]]></description>
                        <content:encoded><![CDATA[<p> </p><blockquote data-userid="523578" data-postid="714031" data-mention="mysticgringo"><div class="wpforo-post-quote-author"><strong> Posted by: @mysticgringo </strong></div><p>Hi...</p><p>I have a few annoying issues that aren't show stoppers, but adds steps to my workflow, and frankly annoy me.</p><p>1. I want the wipe tower to stay put when I hit the arrange button. I like it in the default part of the bed and it's frustrating when arrange moves it to the center part of the print area. Anyway to lock it in location in respect to the arrange function?</p><p>2. If I print something with a "label" using 2 colors, white writing on a black object for example, the slicer won't build the tower the whole way, yet it will cause a purge at the very top of the object. Is there a way to stop this purge that ends up in mid-air? I can show a screen capture from the sliver if it's not clear what I am saying. The "no sparse layers" actually exasperates the problem.</p><p>3. Is there a way to make it print the tower base first before it prints the object. The reason for this is if my last print ended with black or red filament, but this new print starts with white, I want the color purged out before starting the white. I have set up a "white" filament with extra purging, but the slicer tells it to print the object first, and not the tower, so there is no extra purge to start with for the white. My work around is to add a skirt to ensure it purges the color from the nozzle.</p><p>If nobody has good solutions I will likely add these to GitHub so developers can see it.</p><p>Thanks.</p></blockquote><p>Unfortunately, most slicers don’t have an option to lock the wipe tower’s position when arranging other objects. As a workaround, try arranging all parts on the bed manually without using the Arrange button after positioning the wipe tower where you want it. Another option is to group all objects except the tower, so when you hit Arrange, the tower remains untouched.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>Vens Karr</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-general-discussion-announcements-and-releases/prusa-slicer-wipe-tower-issues/#post-725364</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-general-discussion-announcements-and-releases/prusa-slicer-wipe-tower-issues/#post-725347</link>
                        <pubDate>Thu, 24 Oct 2024 22:41:00 +0000</pubDate>
                        <description><![CDATA[Posted by: @antimix @mysticgringo Hi,regarding POINT 3 I don&#039;t have this behaviour. I just tried to slice a PRUSA keychain. PrusaSlicer set the change colour automatically.Then it started wi...]]></description>
                        <content:encoded><![CDATA[<p> </p><blockquote data-userid="70581" data-postid="714168" data-mention="antimix"><div class="wpforo-post-quote-author"><strong> Posted by: @antimix </strong></div><p>@mysticgringo Hi,</p><p>regarding <strong>POINT 3 </strong>I don't have this behaviour. I just tried to slice a PRUSA keychain. PrusaSlicer set the change colour automatically.</p><p>Then it started with the initial purge line, and then <strong>it started the tower to ensure the colour is pure.</strong></p><p><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2024/06/3f1e1bc1-2024-06-21_00-22-12.png"><img class="alignnone size-medium wp-image-168248" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2024/06/3f1e1bc1-2024-06-21_00-22-12-600x500.png" alt="" width="600" height="500" /></a></p><p>Then it moved to start to print the object. When it finished the plate, it went to the tower, removed the filament, purged the material <strong>in the tower structure not on the</strong> <strong>air</strong>, and then continued normally to finish the label letters.</p><p><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2024/06/a867fd9b-2024-06-21_00-27-16.png"><img class="alignnone size-medium wp-image-168249" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2024/06/a867fd9b-2024-06-21_00-27-16-600x500.png" alt="" width="600" height="500" /></a></p><p>keep in mind that all the filament handling is fully automatic through MMU3, <span style="text-decoration: underline">there is no interaction</span> with the LCD panel.</p><p>All the filament colours should be preloaded on the buffer box and on the MMU3 tubes before printing, and the filament colour order should be the same in the corresponding <em><strong>Extruder x</strong></em> colour filaments in PrusaSlicer before slicing.</p><p>Ensure to have set <strong>Original Prusa MKx MMU3 0.4 Nozzle </strong>in print settings.</p><p> </p></blockquote><p>Thanks for advice.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-general-discussion-announcements-and-releases/prusa-slicer-wipe-tower-issues/#post-725347</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-general-discussion-announcements-and-releases/prusa-slicer-wipe-tower-issues/#post-715978</link>
                        <pubDate>Wed, 10 Jul 2024 11:30:49 +0000</pubDate>
                        <description><![CDATA[Hey Antimix...Thanks for trying it, and for figuring out what my issue was, I guess I could have been clearer.For every other print I&#039;ve done, it works as expected the wipe tower first to pu...]]></description>
                        <content:encoded><![CDATA[<p>Hey Antimix...</p><p>Thanks for trying it, and for figuring out what my issue was, I guess I could have been clearer.</p><p>For every other print I've done, it works as expected the wipe tower first to purge the nozzle, and then print the object. I've tested it with numerous copies of this object thinking it was volume of filament that might trigger the purge, and even with 30 copies of the object it still won't do the wipe tower first. I even changed the purge volumes, and it still did not make the wipe tower first.</p><p>So... it's obviously a bug. Guess I'm off to Github with these issues.</p><p>Thanks for trying it, and for confirming my findings.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>MysticGringo</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-general-discussion-announcements-and-releases/prusa-slicer-wipe-tower-issues/#post-715978</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-general-discussion-announcements-and-releases/prusa-slicer-wipe-tower-issues/#post-715933</link>
                        <pubDate>Tue, 09 Jul 2024 19:39:23 +0000</pubDate>
                        <description><![CDATA[@MysticGringo I realized what you mean 😧 and I spent last two hours trying to figure how to justify the behaviour.
Basically I noticed that your project starts the initial purge line, and w...]]></description>
                        <content:encoded><![CDATA[<p><strong>@MysticGringo</strong> I realized what you mean 😧 and I spent last two hours trying to figure how to justify the behaviour.</p>
<p>Basically I noticed that your project <strong>starts the initial purge line, and without a wipe tower </strong>, immediately prints the text object (if you did not had the right colour in the nozzle, then good luck, with colour mesh.... ). It starts immediately the orange text, and then it creates the wipe tower when it is time to print the rectangle of the different colour (yellow lines).</p>
<p>I was not able to force a wipe tower <strong>before</strong> the text object. No way. 😫 </p>
<p><strong>BUT</strong></p>
<p>I have exactly the same thing, a demo Prusa keychain that I have created time ago, and it automagically <strong>starts always creating the wipe tower first and then the object.😣  </strong>But if I try to add one of your object, then your object is printed without wipe tower.</p>
<p><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2024/07/916d5b23-2024-07-09_21-24-42.png"><img class="alignnone size-medium wp-image-168689" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2024/07/916d5b23-2024-07-09_21-24-42-600x500.png" alt="" width="600" height="500" /></a></p>
<p>You will find attached the DEMO Keychain project and you will see that it <strong>always creates the Wipe tower and purge the colour before starting the object.</strong></p>
<p>At the moment I can't figure how I did .... 🤔 </p>
<p>Regards</p>
<div id="wpfa-168690" class="wpforo-attached-file"><a class="wpforo-default-attachment" title="c9f9ee8c-prusa-keychain-test3-prj.zip" href="//storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/wpforo/default_attachments/1720553963-c9f9ee8c-prusa-keychain-test3-prj.zip" target="_blank" rel="noopener"> c9f9ee8c-prusa-keychain-test3-prj.zip</a></div>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>Antimix</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-general-discussion-announcements-and-releases/prusa-slicer-wipe-tower-issues/#post-715933</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-general-discussion-announcements-and-releases/prusa-slicer-wipe-tower-issues/#post-715923</link>
                        <pubDate>Tue, 09 Jul 2024 16:57:39 +0000</pubDate>
                        <description><![CDATA[@MysticGringo Hello, I sliced it and all seems normal to me.It starts normally with the first colour, then it purge, then complete the first layer with the second colour, and then since the ...]]></description>
                        <content:encoded><![CDATA[<p>@MysticGringo Hello, I sliced it and all seems normal to me.</p><p><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2024/07/654aa9cf-2024-07-09_18-52-02.png"><img class="alignnone size-medium wp-image-168686" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2024/07/654aa9cf-2024-07-09_18-52-02-495x500.png" alt="" width="495" height="500" /></a></p><p>It starts normally with the first colour, then it purge, then complete the first layer with the second colour, and then since the colour is the same, it completes the object.</p><p><em><strong>- Did you encounter any issue ?</strong></em></p><p><strong>NOTE</strong>: My MK4 has no MMU3. The MMU3 is installed on the MK3.5. However I used all the settings in your file without any change, I just sliced, and there were no problems.</p><p>Regards</p><p> </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-general-discussion-announcements-and-releases/prusa-slicer-wipe-tower-issues/#post-715923</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-general-discussion-announcements-and-releases/prusa-slicer-wipe-tower-issues/#post-715908</link>
                        <pubDate>Tue, 09 Jul 2024 14:16:02 +0000</pubDate>
                        <description><![CDATA[Hey Antimix (or anybody else) would you mind trying to slice this file and see what it puts down first, the writing, or the wipe tower? I just did this one today and it out the lettering dow...]]></description>
                        <content:encoded><![CDATA[<p>Hey Antimix (or anybody else) would you mind trying to slice this file and see what it puts down first, the writing, or the wipe tower? I just did this one today and it out the lettering down first, and then the wipe tower.</p>
<p>(ugh, if I can figure out how to attach the file).</p>
<p>Thanks.</p>
<div id="wpfa-168682" class="wpforo-attached-file"><a class="wpforo-default-attachment" href="//storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/wpforo/default_attachments/1720534629-690327dd-panel-label.zip" target="_blank" title="690327dd-panel-label.zip"><i class="fas fa-paperclip"></i>&nbsp;690327dd-panel-label.zip</a></div>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-general-discussion-announcements-and-releases/prusa-slicer-wipe-tower-issues/#post-715908</guid>
