					                		MMU3 and carbon fiber reinforced filaments - General discussion, announcements and releases                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-general-discussion-announcements-and-releases/mmu3-and-carbon-fiber-reinforced-filaments/</link>
                <lastBuildDate>Wed, 13 May 2026 06:45:35 +0000</lastBuildDate>
                        <title>RE: MMU3 and carbon fiber reinforced filaments</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-general-discussion-announcements-and-releases/mmu3-and-carbon-fiber-reinforced-filaments/#post-728445</link>
                        <pubDate>Fri, 29 Nov 2024 12:07:01 +0000</pubDate>
                        <description><![CDATA[I am well noted of the information, thank you. 😀]]></description>
                        <content:encoded><![CDATA[<p>I am well noted of the information, thank you. 😀 </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>gihl3d</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-general-discussion-announcements-and-releases/mmu3-and-carbon-fiber-reinforced-filaments/#post-728445</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-general-discussion-announcements-and-releases/mmu3-and-carbon-fiber-reinforced-filaments/#post-728143</link>
                        <pubDate>Tue, 26 Nov 2024 17:00:20 +0000</pubDate>
                        <description><![CDATA[Currently, Prusa slicer only allows pla and petg for multi material auto load or selection with mmu setups.  For unsupported filaments you program them as a non mmu program.  When run with t...]]></description>
                        <content:encoded><![CDATA[<p>Currently, Prusa slicer only allows pla and petg for multi material auto load or selection with mmu setups.  For unsupported filaments you program them as a non mmu program.  When run with the mmu, you need to tell it which mmu slot to use.   Example I have asa in mmu slot 3.  Then slice my part as a simple mk4s using asa.  When loaded and run, I need to assign the asa filament to mmu slot 3 on the mk4s menu screen.  Then it loads and unloads from mmu slot 3.      This assignment is done every time you run a non mmu program when the mmu is enabled on the mk4.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>vhubbard</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-general-discussion-announcements-and-releases/mmu3-and-carbon-fiber-reinforced-filaments/#post-728143</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-general-discussion-announcements-and-releases/mmu3-and-carbon-fiber-reinforced-filaments/#post-728112</link>
                        <pubDate>Tue, 26 Nov 2024 09:15:02 +0000</pubDate>
                        <description><![CDATA[Should be fine with PLA-CF.Flexible filaments do not work with any external feeding system (although Bamboo Lab have just released a slightly different version of flexible filament that is A...]]></description>
                        <content:encoded><![CDATA[<p>Should be fine with PLA-CF.</p><p>Flexible filaments do not work with any external feeding system (although Bamboo Lab have just released a slightly different version of flexible filament that is AMS compatible...)</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>iftibashir</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-general-discussion-announcements-and-releases/mmu3-and-carbon-fiber-reinforced-filaments/#post-728112</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-general-discussion-announcements-and-releases/mmu3-and-carbon-fiber-reinforced-filaments/#post-727310</link>
                        <pubDate>Mon, 18 Nov 2024 15:18:28 +0000</pubDate>
                        <description><![CDATA[Yes, I expected MMU to be able to easily use PLA-CF, PA-CF, TPE, etc. 🤔 Thanks for the detailed explanation. 😀]]></description>
                        <content:encoded><![CDATA[<p>Yes, I expected MMU to be able to easily use PLA-CF, PA-CF, TPE, etc. 🤔 </p><p>Thanks for the detailed explanation. 😀 </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-general-discussion-announcements-and-releases/mmu3-and-carbon-fiber-reinforced-filaments/#post-727310</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-general-discussion-announcements-and-releases/mmu3-and-carbon-fiber-reinforced-filaments/#post-727215</link>
                        <pubDate>Sun, 17 Nov 2024 11:50:46 +0000</pubDate>
                        <description><![CDATA[I think that would work for the filament change. You can also use the nozzle. I can&#039;t tell you whether flexible material will work, probably not. Normally you also have to loosen the screws ...]]></description>
                        <content:encoded><![CDATA[<p>I think that would work for the filament change. You can also use the nozzle. I can't tell you whether flexible material will work, probably not. Normally you also have to loosen the screws on the idler.</p><p>If you are printing material that is sensitive to moisture, you should consider that the material in the buffer is in the open.I have solved it like <a href="https://www.printables.com/model/1009131-filament-drybox-and-buffer-for-mmu" target="_blank" rel="noopener">this</a>.</p><p>My opinion is that if you really only want to change the filament easily, don't do it.The MMU already adds a lot of complexity to the system.Only if you want to start printing a lot of spools is the MMU very practical.</p><p> </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>Rainer</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-general-discussion-announcements-and-releases/mmu3-and-carbon-fiber-reinforced-filaments/#post-727215</guid>
                        <title>MMU3 and carbon fiber reinforced filaments</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-general-discussion-announcements-and-releases/mmu3-and-carbon-fiber-reinforced-filaments/#post-727154</link>
                        <pubDate>Sat, 16 Nov 2024 15:28:48 +0000</pubDate>
                        <description><![CDATA[Hello from South Korea. 😀I have installed E3D High Flow ObXidian Prusa Nozzle on MK4S and I am printing mostly with PLA-CF filaments.I use eSUN PLA-CF filaments, mostly black, but often gree...]]></description>
                        <content:encoded><![CDATA[<p>Hello from South Korea. 😀</p><p>I have installed E3D High Flow ObXidian Prusa Nozzle on MK4S and I am printing mostly with PLA-CF filaments.</p><p>I use eSUN PLA-CF filaments, mostly black, but often green and purple as well.</p><p>And additionally, I would like to use eSUN PA-CF and eSUN eLastic(TPE-83A).</p><p> </p><p>I'm considering the MMU3 to reduce the hassle of changing filaments, can I use the MMU3 in this case?</p><p>and can I still use the E3D High Flow ObXidian Prusa Nozzle in this case?</p><p>I would really appreciate your advice. </p><p>Thanks.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-general-discussion-announcements-and-releases/mmu3-and-carbon-fiber-reinforced-filaments/#post-727154</guid>
