					                		Migrating MMU3 from Mk3S+ to Core One? - General discussion, announcements and releases                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-general-discussion-announcements-and-releases/migrating-mmu3-from-mk3s-to-core-one/</link>
                <lastBuildDate>Thu, 21 May 2026 02:24:28 +0000</lastBuildDate>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-general-discussion-announcements-and-releases/migrating-mmu3-from-mk3s-to-core-one/#post-766901</link>
                        <pubDate>Mon, 13 Oct 2025 11:10:12 +0000</pubDate>
                        <description><![CDATA[When I upgraded my Mk4 to an Mk4S I do not remember having to upgrade any part for the MMU.
Assembly manual for the upgrade :
The Y axis upgrade is not important.The LCD upgrade is only the...]]></description>
                        <content:encoded><![CDATA[<p>When I upgraded my Mk4 to an Mk4S I do not remember having to upgrade any part for the MMU.</p>
<p>Assembly manual for the upgrade : <br />https://help.prusa3d.com/manual/original-prusa-mk4-mk3-9-to-mk4s-mk3-9s-upgrade_2186</p>
<p>The Y axis upgrade is not important.<br />The LCD upgrade is only the faceplate (cosmetic) so not important</p>
<p>The Nextruder upgrades : <br />  Nextruder faceplate (With the Mk4 name) , mostly cosmetic but the Core One has its own face plate so no problem?<br />  The Part Cooling Fan : the new part cooling fan is re-used in the Core One so no problem expected.<br />  A high flow nozzle is installed , for the MMU a normal flow nozzle is advised<br />  Check the bowden couplers as Prusa advises here : <br />  https://help.prusa3d.com/guide/1-conversion_793793#898178</p>
<p>Upgrading connectivity , these parts are also used on a Core One.</p>
<p>So my conclusion was : If you already have the filament detection parts updates on your Mk4 the MMU should also work on the Core One<br />The printable parts for this update can be found here : <br />https://www.printables.com/model/531604-mmu3-printable-parts/files<br />Inside the folder : CORE ONE &amp; MK4 &amp; MK3.9 Nextruder parts - R2 <br />So if you have the parts for this upgrade (it does use a few NON printable parts) it should work</p>
<p>The Core One nextruder upgrade is doen in this assemblt manual step :<br />https://help.prusa3d.com/guide/9d-core-one-nextruder-mod_111779<br />So you can check if you have all NON Printable parts.</p>
<p>The only question I have is if the original Buddy Board to MMU3 cable is long enough.<br />But the conversion kit does not have a new cable so I guess it is long enough.</p>
<p>(Edited to add Cone One nextruder assembly manual)</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>What-ever</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-general-discussion-announcements-and-releases/migrating-mmu3-from-mk3s-to-core-one/#post-766901</guid>
                        <title>RE: Migrating MMU3 from Mk3S+ to Core One?</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-general-discussion-announcements-and-releases/migrating-mmu3-from-mk3s-to-core-one/#post-765864</link>
                        <pubDate>Tue, 30 Sep 2025 10:03:10 +0000</pubDate>
                        <description><![CDATA[I have the same question]]></description>
                        <content:encoded><![CDATA[<p>I have the same question</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>Koos</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-general-discussion-announcements-and-releases/migrating-mmu3-from-mk3s-to-core-one/#post-765864</guid>
                        <title>Migrating MMU3 from Mk3S+ to Core One?</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-general-discussion-announcements-and-releases/migrating-mmu3-from-mk3s-to-core-one/#post-760663</link>
                        <pubDate>Mon, 11 Aug 2025 05:16:23 +0000</pubDate>
                        <description><![CDATA[I think it&#039;s finally time to bite the bullet and replace my old Mk3S+ with a new Core One. I already have the MMU3 unit for my Mk3, and I&#039;d like to transfer that over to the Core One. I was ...]]></description>
                        <content:encoded><![CDATA[<p>I think it's finally time to bite the bullet and replace my old Mk3S+ with a new Core One. I already have the MMU3 unit for my Mk3, and I'd like to transfer that over to the Core One. I was surprised to find there doesn't seem to be any official instructions for that transition, though there are instructions for transferring the MMU3 from the <a href="https://help.prusa3d.com/manual/original-prusa-mk3s-mmu3-to-mk4-mk3-9-mmu3-upgrade_2156/mmu3" target="_blank" rel="noopener">Mk3S+ to a Mk4</a>, and from a <a href="https://help.prusa3d.com/guide/1-conversion_793793#898178" target="_blank" rel="noopener">Mk4 to a Core One</a>.</p><p>The instructions for the Mk4 to Core One transfer mention that "Core One is only compatible with the latest versions of the MMU3 units, specifically those used on the MK4/S". So does that mean there's no viable upgrade path? The comments on that page seem to imply the only difference is the color and size of the fittings, <a href="https://www.prusa3d.com/product/fitting-m5-4/" target="_blank" rel="noopener">which can be replaced</a>. Though I know the wiring harness is different for the Mk3 as well, but <a href="https://www.prusa3d.com/product/mmu3-printer-cable-550mm/" target="_blank" rel="noopener">that can likewise be replaced</a>. I suspect that those items, in addition to the MMU3 Conversion Kit for Core One might be the only parts I need? Maybe also a new PTFE tube? Has anyone else attempted this particular process? Is there anything else I'm overlooking, or some fundamental issue making this upgrade impossible?</p><p>Thanks in advance!</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>Patronics</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-general-discussion-announcements-and-releases/migrating-mmu3-from-mk3s-to-core-one/#post-760663</guid>
