I want to buy MMU3 for MK3.5S, but there is no option at the shop
As the title says, I want to buy an MMU3 for my MK3.5S, but the store only has the options for “MK3.9S / MK4S” and “MK3S+”, with the option for the “MK3S+” being sold out.
A google search led me to the site “ https://www.prusa3d.com/de/produkt/original-prusa-mmu3-upgrade-kit-for-mk3-5s-mk3-5-8/ ”, but it no longer exists.
Prusa's chat referred me to the same page, but when I said that it no longer existed, he didn't really know what to do.
Did I miss something, that there is no MMU3 for the MK3.5S anymore?
RE: I want to buy MMU3 for MK3.5S, but there is no option at the shop
I'm here to figure this out. I chatted with support from Prusa and they were very confusing, linking me to a list of parts needed to update a MMU2 to an MMU3.
Seems like Prusa doesn't supply the MK3S+ hotend upgrade parts in the kit anymore, but the files needed for the MK3S+ hotend update are on Printables and some individual parts are available for sale. You would need the MMU3 kit and then print the MK3S+ hotend update parts. The instructions for the MK3S+ update are still in the MMU3 assembly instructions. See https://www.printables.com/model/531604-mmu3-printable-parts/files for the MMU3 parts. There is an MK3S+ section with the parts you need to print for the hotend updates.
You need to find the insert for the "Chimney-Base" or just buy the Chimney-Base from Prusa with the insert in it. https://www.prusa3d.com/product/chimney-base/
I would also replace the PTFE tube in the hotend if you have many hours on the printer. That is part of the MMU3 instructions for the MK3S+ hotend update.
I upgraded my MK3S+ for the MMU, but it is now an MK4S.
I hope this helps
Thank you this was really helpful, so the main discriminator is just making sure that I can upgrade the MK3S+ hotend following the steps in the instructions for that and can just order the MMU3 for MK4S and be ok?
Why couldn't support just explain that??
Sorry for my late answer.
at the meantime i got an answer from support:
Thank you for your message. Unfortunately, some variants of the MMU have stopped production, these are the variants:
- Original Prusa MMU2S to MMU3 upgrade for MK3.5
 - Original Prusa MMU2S to MMU3 upgrade for MK3S+
 - Original Prusa MK3S+ MMU3 upgrade kit to MK4/MK3.9
 - Original Prusa MK3S+ MMU3 upgrade kit to MK4S/MK3.9S
 - Original Prusa MMU3 for MK3.5/MK3.5S Assembled unit
 - Original Prusa MMU3 for MK3S+ Assembled unit
 - Original Prusa MMU3 for MK3.5 Printed Parts
 - Original Prusa MMU3 for MK3.5S/MK3.5
However, the next guide is a parts list that shows the required parts to build and upgrade your MMU3. We sell the majority of the parts on our e-shop, and you can print the required parts by following the links. The fasteners are quite easy to source locally.
https://help.prusa3d.com/article/list-of-parts-for-mmu2s-to-mmu3-upgrades_887521
Now i have ordered some parts for MMU3 (MMU2) and want to build the UltiMulti MMU3
https://www.printables.com/model/537888-mmu3-ultimulti-printable-parts
Thanks for your help
